I'll do my best to assist you in finding a manual for the Centrios Atomic Clock Radio 121-9023.
Unfortunately, I wasn't able to find a direct link to a manual for this specific model of clock radio. However, there are a few steps you can take to try to locate a manual:
Check the manufacturer's website: Centrios is a brand sold by The Source, so you could try visiting The Source's website and searching for the manual there. Look for a "Support" or "Downloads" section on the website. If you don't find the manual there, you could try contacting The Source's customer service for assistance.
Search online manuals databases: You could try searching online databases of manuals, such as ManualsLib or ManualsOnline. These websites host manuals for many different products, so it's possible that someone has uploaded a manual for the Centrios Atomic Clock Radio 121-9023.
Search for similar models: If you can't find a manual for the exact model number you have, try searching for manuals for similar models. Sometimes, manufacturers will use similar designs and functions across different models. Look for a model number that's close to yours, and see if the manual for that model provides any helpful information.
I hope one of these methods helps you locate the manual you need. Good luck!
We also have this problem. Found this info in the product's Q&A on the website: http://answers.thesource.ca/answers/9026/product/1218694/centrios-centrios-ipod-iphone-clock-radio-white-questions-answers/questions.htm
"Ok. there is a way that you can LOWER the wakeup radio volume. turn on
the radio (forget about the alarm right now) and go to the station that
you want. when you get to the station, you should be able to press the
'skip/fast forward' button on the remote. when you do this, number 5
should show up beside the station #. When you do this, it lowers the
overall volume of every volume level, so now level 19 is equal to volume
level 9/10, which for me is loud enough to wake me, but not give me a
heart attack! so, now when the alarm goes of, the volume is a lot lower.
BUT if you want to wake up to your ipod, this method will NOT work, it
will still be up at level 19. so when you turn on your ipod, it will be
really LOUD. again, this only works with the radio."
Also if you are waking to ipod and not radio this was in the reviews: "Fooled with it for a bit and discovered that
you have to turn down the volume of the iPod first before putting it on
the dock. We've tried it a few times just to make sure and it worked
every time!!"
Still not a perfect solution, but a great improvement. Hope this helps someone.
[email protected] I just oiled my fan with an electronics oil and put everything back together...worked good all night.....I am wondering if the fan is supposed to **** air into the internet radio, or **** air out. It allmost looks as if it was engineered to **** air into model #1315117 Centrios Internet radio...Can someone advise if it should be sucking air into the internet radio or taking air out.
Setting the clock 1. Press SETUP in no disc mode or full stop mode,MENU screen appears on the TV screen. 2. Using v select SETUP MENU, then press ENTER or >, BASIC SETUP is highlighted. 3. Using v to select “Set Clock ”, then press ENTER or >, “Set Clock Setup ”screen appears. 4. Press</>/^/v repeatedly (or numeric buttons) to set the date and time. 5. Press > to select “Done”or“Cancel ”, and then press ENTER , BASIC SETUP returns. 6. To exit, press SETUP. 7. Press POWER to turn off the unit, the clock appears on the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
I lost my remote somewhere , so I went out and brought another remote But I dont have the codes to make it work on my centrios DVD recorder can your help me THANK - YOU
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
