Fisher and Paykel DD60DDFX6 Dishwasher Logo
Question about Fisher and Paykel DD60DDFX6 Dishwasher
Top mounting brackets
Where to buy
F.P.D.Draw Alt Solutions
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Posted on Oct 03, 2014
2answers
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Can I wall mount my proview tv? do I need to buy a particular mounting bracket?
You can wall mount your Proview TV with any standard VESA mounting system that is certified for up to the size of you tv.
6helpful
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
2helpful
4answers
I cannot get the alternater out of my 1997 Dodge Grand Caravan. It is a 6 cylindar 3.3 engine. The Chilton manual is no help at all. I have managed to remove all the bolts holding it on, but I cannot even...
3.3L & 3.8L Engines
  1. Disconnect the negative battery cable.
  2. Remove the windshield wiper/motor module assembly.
  3. Remove the accessory drive belt.
  4. Remove the bolt securing the top of the alternator mounting bracket to the engine air intake plenum.
  5. Remove the bolts securing the outside of the alternator mounting bracket to the alternator mounting plate.
  6. Remove the bolt securing the top of the alternator to the mounting bracket.
  7. Remove the alternator mounting bracket from the vehicle.
  8. Rotate the alternator toward the dash panel.
  9. Unplug the push-in field wire connector from behind the alternator.
  10. Remove the B+ nut and wire from behind the alternator.
Alternator removal-3.3L and 3.8L engines
  1. Remove the bolt securing the bottom of the alternator to the lower pivot bracket.
  2. Remove the alternator from the vehicle.
To install:
  1. Install the alternator into position on the vehicle's engine.
  2. Install the bolt securing the bottom of the alternator to the lower pivot bracket.
  3. Connect the B+ wire and tighten the retaining nut to 75 inch lbs. (9 Nm).
  4. Plug in the push-in field wire connector onto the back of the alternator.
  5. Rotate the alternator forward away from the dash panel.
  6. Install the alternator mounting bracket in position on the vehicle.
  7. Install the bolt to secure the top of the alternator to the mounting bracket.
  8. Install the bolts to secure the outside of the alternator mounting bracket to the alternator mounting plate.
  9. Install the bolt to secure the top of the alternator mounting bracket to the engine air intake plenum.
  10. Tighten all of the alternator mounting bolts to 40 ft. lbs. (54 Nm).
  11. Install the accessory drive belt. Be sure the drive belt is correctly routed on the engine and correctly seated on all of the pulleys.
  12. Install the windshield wiper/motor module assembly.
  13. Reconnect the negative battery cable.
  14. Verify the charging rate of the alternator.
LET ME KNOW IF THIS HELPED.
2answers
Using a Wall Air Condtioner in Window
It is called a mounting kit and can be purchased at Home Depot, Lowes, or an appliance store.
2helpful
2answers
Dishwasher tils when door is open because the bracket is roken
There is now a universal dishwasher bracket for just this problem called E-Z DISHWASHER BRACKET. It is available through Braxton-Bragg or ask for it at a local granite fabricator. It is very simple to use.
2helpful
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Open Questions:
See all Fisher and Paykel DD60DDFX6 Dishwasher Questions
Top Fisher Dishwashers Experts
vince
Paul
NOEL
NOEL
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
