HP Color LaserJet 4600n Printer Logo
A
Anonymous Posted on Aug 14, 2014
How to replace pickup rollers - HP Color LaserJet 4600n Printer
  • Todd Simms
    Todd Simms Feb 19, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? which tray, the manual feed tray(tray 1) or the normal tray on the bottom(tray2)?
  • Michael Dorman
    Michael Dorman Apr 18, 2018
    The two small rollers that touch to top of the bills
George Mclaughlin
Level 2:
Sergeant:
  • HP Expert 372 Answers
  • Posted on Jul 02, 2015
George Mclaughlin
HP Expert
Level 2:
Sergeant:
Answers
372
Questions
Helped
128168
Points
839
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
How to replace the adf pickup/roller assembly on a Brother MFC-L8900cdw? Mine is starting to pull 2-3 sheets of paper at a time
To replace the ADF pickup/roller assembly on a Brother MFC-L8900cdw printer, follow these steps:
  1. Turn off the printer and unplug it from the power outlet.
  2. Open the automatic document feeder (ADF) cover and remove any paper from the feeder.
  3. Locate the ADF pickup/roller assembly. It is located underneath the ADF cover and consists of a set of rollers that are used to feed paper into the printer.
  4. Use a small screwdriver to remove the screws that secure the ADF pickup/roller assembly in place.
  5. Carefully lift the ADF pickup/roller assembly out of the printer.
  6. Install the new ADF pickup/roller assembly by aligning it with the mounting holes and securing it in place with the screws.
  7. Close the ADF cover and plug the printer back in.
  8. Turn the printer on and test the ADF to make sure it is functioning properly.
If you are having difficulty replacing the ADF pickup/roller assembly or if the problem persists after replacing it, it may be necessary to have the printer serviced by a professional. A technician will be able to diagnose the problem and determine the necessary repairs.
Pickup roller
search trought service manual and see service menu for reset counter for pickup roller
2answers
HP LJ p2015 How do you replaced the feed roller on the 250 sheet tray? It is not in the service manual?
HP LaserJet P2015 Series Printer - Replace the pickup roller (tray 1)
  1. Unplug the power cord from the printer, and allow the printer to cool.
  2. Press the print-cartridge-door button to open the print-cartridge door.
  3. Remove the print cartridge.
    After removing the print cartridge, only handle it on the ends.
  4. Grasping the pickup-roller cover with thumb and forefinger, squeeze the left side of the pickup-roller cover to release the left retaining tab, and then slide the cover to the left and up.
    Failure to slide the cover to the left when removing it can cause the right retaining tab to break.
  5. Press the two black retaining tabs outward until the pickup roller is released from its seat.
  6. Remove the old pickup roller from the printer.
  7. Line up the black retaining tabs in the printer with the grooves in the new pickup roller, and then press the pickup roller into the pickup-roller seat until the retaining tabs click.
    Do not touch the pickup-roller pad.
  8. Grasping the pickup-roller cover with thumb and forefinger, insert the pickup-roller cover's right retaining tab into the retaining slot.
  9. Squeeze the left side of the pickup-roller cover and insert the left retaining tab in the retaining slot.
  10. Close the print-cartridge door.
  11. Plug the printer in.
HP P3005DN Tray 2 pickup roller does not turn. Hear clicking sound but roller doesn't turn to pickup and feed paper.
Hi
This is a problem with the Pickup roller.
Try to inspect the paper pickup roller, on the right side of the roller you can find a small notch which gets coupled with the shaft it will be broken. You have to replace the roller.
Regards
1helpful
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
HP Business Ink-jet 1200 1) when it starts printing and the paper feeds it makes an extremely loud clunk sound regardless of the paper tray being used. 2) each and every time the paper comes through it...
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
2. Open the toner cartridge door, and
remove the toner cartridge.
3. Locate the pickup roller.
4. Release the small, white tabs on
each side of the pickup roller by
pushing them away from the roller,
and then rotate the pickup roller
toward the front.
5. Gently pull the pickup roller up and
out.
6. Position the new pickup roller in the
slot of the previous pickup roller.
Note Circular and rectangular pegs on each
side prevent you from incorrectly
positioning the pickup roller.
7. Rotate the top of the new pickup
roller into position until the white
tabs on each side of the roller snap
the roller into place.
8. Reinstall the toner cartridge, and
close the toner cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
2answers
Got a new part. don't know how to install it
I assume you either have recieved the separation pad or the paperpick roller. Here are instructions on how to replace both.
  1. Use the power switch to turn the product off and then unplug the power cord. Figure 1: Unplugging the power cord c00062340.gif
  2. Open the print-cartridge door, and remove the print cartridge. CAUTION: To prevent damage, do not expose the print cartridge to light. Cover the print cartridge or place it in a black plastic bag, if necessary. Also, do not touch the black-sponge transfer roller inside the product. Touching the transfer roller can damage the product.
  3. Locate the pickup roller. Figure 2: Removing the print cartridge, and locating roller c00062341.gif
  4. Gently release the small, white tabs on each side of the pickup roller by pushing them away from the roller, and then rotate the pickup roller toward the front. CAUTION: Use gentle pressure to release the small white tabs to avoid breaking them. Figure 3: Releasing the tabs c00062342.gif
  5. Gently pull the pickup roller up and out. Figure 4: Removing pickup roller c00062343.gif
  6. Perform one of the two following options:
    • Cleaning the pickup roller:
      1. Dampen a lint-free cloth with isopropyl alcohol, and scrub the roller.
      2. Using a dry lint free cloth, wipe the pickup roller to remove loosened dirt. Figure 5: Wiping the pickup roller c00062344.gif
    • Removing the new pickup roller from its packaging.
  7. Position the cleaned or replacement pickup roller in the slots on the pickup roller frame. NOTE: Circular and rectangular pegs on each side prevent incorrectly positioning the pickup roller. Figure 6: Positioning pickup roller c00062345.gif
  8. Rotate the top of the pickup roller into position until the white tabs on each side of the roller snap into place. NOTE: Touching the transfer roller can damage the product. Figure 7: Reinstalling the pickup roller c00062346.gif
  9. Reinstall the print cartridge and close the print-cartridge door.
  10. Plug the product in, and then use the power switch to turn on the product. Figure 8: Plugging the power cord in c00062347.gif
  11. Use the power switch to turn the product off and unplug the power cord. Figure 1: Turning off power and remove power cord c00062407.gif
  12. At the back of the product, unscrew the two screws that fasten the separation pad and frame to the product. Figure 2: Unscrewing the separation pad c00062408.gif
  13. Remove the separation pad and frame. Figure 3: Removing the separation pad c00062409.gif
  14. Perform one of the following two options:
    • To clean the separation pad: Dampen a lint-free cloth with isopropyl alcohol, and scrub the separation pad.
    • To replace the separation pad: Remove the new separation pad from its packaging
  15. Insert either the cleaned or replacement separation pad and frame and fasten it to the product with the two screws. Figure 4: Fastening the separation pad c00062410.gif
  16. Plug the product in, and then use the power switch to turn on the product. Figure 5: Turning the product on c00062411.gif
1helpful
2answers
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
2helpful
3answers
Rollers are leaving black smudges on my checks
Are you positive that this is a 'roller' problem.  Black smudges usually indicate a drum problem (your toner cartridge).  If you pull it out, you'll see a flap that should move back and forth.  If you move that flap, you'll see a shiny cylendar.  That's the drum.  See if you can see any marks on it (don't touch it with your hands.)
The problem is, it's hard to tell whether or not it's the drum just by looking.  Your best bet is to see if replacing the cartridge takes care of the problem.
k24674
Grand Canyon Tech
Grand Canyon Tech
