Question about Canon Pixma MP500 All-In-One InkJet Printer
Why is my printer is not printing at all
I've performed all the cleaning procedures, changed the inks but still it won't print
5 Related Answers
Anonymous
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
Anonymous
SOURCE: canon bjc-85 printer doesn't print anymore
My 1st brand new cartridge and ink tanks did not work. I took them out and put in my other new ink cartridge and ink tanks, and now it works fine.
Posted on Aug 06, 2008
Bogdy_3003
Bogdan Beldea
  • 17 Answers
SOURCE: Canon i9900 printer will not print group 2 colors.
Set your printer at maximum quality and dpi
Posted on Dec 27, 2008
Anonymous
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
Anonymous
  • 68 Answers
SOURCE: Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
Posted on May 28, 2009
Lexmark 730 not printing
Regarding the Lex1 cartridge's no printing/severe fade (or similar) during printing, my answers are provided below:
For the poor print quality problem (degraded image quality) you are observing, we suggest you first visit the "Print Quality" page of the "General Information" section of the Inkjet 411 website and follow the suggestions provided: http://inkjet411.com/?page_id=1432
A. 1. Cartridge & Printer maintenance should also be evaluated - ensure both ink cartridges and flexible driver contact cables (where the cartridge interfaces to the carriage inside the printer) are thoroughly clean: http://inkjet411.com/?page_id=1519
A.2. Perform a hot-water flush on the suspect ink cartridge, refer to video procedure here: http://inkjet411.com/?page_id=1519
A.3. Run a quick test print to evaluate cartridge performance (i.e. 4-color test print):
http://inkjet411.com/?page_id=146
For information on North American ink refill services (for Lexmark 1, 2 and 3 ink cartridges) at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced Lexmark printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Jul 16, 2013 | Lexmark Office Equipment & Supplies
Yellow ink won't print
Verify the ink level and perform in the mantenace mode head cleaning.
Feb 21, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
Dec 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Canon Pixma MP500 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
