Question about Panasonic SC-HT730 System
SA-HT730 DISC PLAYER WILL NOT WORK. DISPLAY ON PLAYER SAYS " INIT", AND NOTHING ELSE WILL HAPPEN. SEEMS TO BE GETTING POWER.ANY HELP WOULD BE GREATLY APPRECIATED
Posted by TVTERRY on
  • 8 more comments
  • Giorda Nov 12, 2007
    I have the same problem. Actually the system stop working about 3 months after the 1 year warranty expired.
    No help form Panasonic customer service. I took it to a service center for an estimate........about $350 to fix it.
    I'm just going to buy a new system...but not Panasonic.
    No more Panasonic in my house!!!!!!!!!!!!!!!!!!!!!!
    Gio
  • Anonymous Nov 29, 2007
    Same problem, init shows on screen. Only two years old or less.
  • BLACKBIRDXX Dec 28, 2007
    SAME PROBLEM AS THE OTHERS THAT HAVE POSTED . INIT ON THE SCREEN , NOTHING WORKS ?????????
  • bobschar69 Feb 14, 2008
    Same problem as the other posting. Init shows and nothing works.
    Brought to Best Buy but will charge $250.oo for repair. Same thing with my friend also same problem.
  • Anonymous Apr 06, 2008
    The Color on my DVD player is out, and I tried to get it back and can't. on live TV the picture is fine. I have a Panasonic 42" Plasma. The start Image was Blue and now it is Green,
  • burritone Apr 23, 2008
    yes i got the same problem
  • Anonymous Jun 24, 2008
    i have a sa-ht733 displays init when on button is push on and stay like that forever.any help?
  • 8acidman8 Aug 23, 2008
    Same problem as the others. Player doesn't work and displays INIT. No help from Panasonic. However, after reading about others who got repair quotes that were close to or equal to the cost I decided there was no risk in giving it a shot myself. There are two screws on each side and three on the back. Remove these and pop the top. Remove any stuck disk and then plug it in to see if the drawer will open. mine did. I then plugged it in with the cover still off, inserted a CD, and I'm listening to music as I write this. Good luck to all.
  • Anonymous Sep 21, 2008
    I have sa-ht730 which was working fine but now all i get is INIT, and nothing else , is there any solution to this problem, thank you for any help jerry  [email protected]
  • leorisuenho Apr 16, 2009
    i have the same problem what i can do to fix it?
Anonymous
I have a panasonic sc-ht730 and everytime I try to watch a dvd it will play for a little while and then freeze up. I have tried it over and over and it freezes up at different times but always toward the first of the dvd. Thanks if anyone could help me with this problem.
Posted on Sep 15, 2008
Anonymous
Fixed Mine!!!!
My Home theatre started to do the same thing today and I manged to get it going again by reseting the ratings password and changing the batteries in my remote. Oddly enough, I have never set a ratings password so I suspect the batteries caused the issue. Seems to be back to normal. Instructions for the reset are in the manual. Here's a link to the online one at Panasonics website http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Posted on Dec 29, 2007
  • Anonymous Jan 09, 2008
    It would appear that I spoke too soon. The DVD player stopped working again and when I tried to reset the unit again, it went back into the INIT loop. I can't believe that Panasonic would sell a P.O.S unit that dies after 2 years of use! I now have a service manual for the unit but it pretty much says to start replacing components. I also have the firmware update CD and I’ll have a recovery CD shortly. I’d like to post them all online to see if someone can figure out what is causing this error.
Anonymous
Need help with the above problem it just shows INIT and nothing else happens. would appricate any advice on this issue , thank you [email protected]
Posted on Sep 21, 2008
Anonymous
SCHT730 ....Same issue as freeze up. I am replacing the flat cable that runs to the DVD optical from what I can tell trouble shooting myself there is a short in this cable. Of course the cost of service manual or someone to look at it on the bench makes it dumpster fill. This is the second in 2 years , the first right out of the box (no digital display) the second lasted 13 months with no help from Panasonic or Circuit City. My suggestion is junk and stay away from Panasonic
Posted on Oct 28, 2008
Anonymous
My player works fine for 10 min the the picture goes all fuzzy ,the sound is fine. When I put in a lens cleaner the instructions come up on the scene fine it even has a section for testing the speakers and all the visual diagrams show up crystal clear
Posted on Apr 04, 2008
Giorda
Mine died after 1 year and 3 months of (light) use...
It sucks...but I bought a new one (not Panasonic)
Posted on Jan 09, 2008
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
DVD player disc tray won't open
take a screw driver and open it up
maybe its a disc that stuck
if not working
probably cheaper to buy a new one
Apr 28, 2009 | Philips DVD793CH Multi-disc DVD Player
Tray won't open!
Hi, not being too familiar with this model ( i.e. whether a single disc or 5 disc changer). it sounds like the CD player section is trying to find home position and will not continue until it has done so. It is very likely that there is a disc in the mechanism and depending how competent you are with a screwdriver, you may be able to release the disc either by removing the top cover or check on the underside of the machineto see if there is a hole in the bottom where you can wind the cd mechanism to the eject position.
Dec 29, 2008 | Panasonic SC-HT940 System
Mini Disc Not Working
Pull the power cord. Make sure the three-position switch with "REC/Standby/PLAY" is in the middle position, then plug the cord back in. Wait a minute, then press POWER. Now load a disk and wait 1 minute for it to read the Table of Contents (TOC). Either it will show the tracks, or it will say 'empty disk'. Let us know what happens from there, okay?
Oct 06, 2008 | Sony MDS-JE480 Mini Disc Player
"LOAD" Showing on the display
Exactly the same problem myself. Try pressing open and then holding tight to a cotton bud, sweep inside the machine. The problem seems to be dust collecting. If it works then get a proper cleaning disc. My problem got so bad that the machine would spit out most discs as unable to read.
May 16, 2008 | Samsung DVDR120 DVD Recorder
Wont read disc-error message HO7
check out this link I think this information will help you. http://www.ledcar.com/pdvdh07/
Sep 17, 2006 | Panasonic DVD-CV47 Multi-disc DVD Player
Panasonic SC-HT730 System Logo
2,222 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
