Lens extends in a few seconds withdraws note on screen is lens error and the picture is fussy.
SOURCE: Lens does not retract fully
Please follow these instructions to fix the lens problem:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
Fix #2:
Remove the batteries, then remove the memory card. Then install the new
batteries, when you turn it on it should come back to life. Error E30
means you don't have a memory card installed, so turn it off, slip in
the memory card and turn it on one last time.
Fix #3:
Insert the cameras AV cable, and turn the camera on in picture review
mode. Have no idea why this would work, except that quite a few people
have reported some success with it.
Fix #4:
Place the camera flat on its back on the kitchen table, pointed at the
ceiling. Press and hold the shutter button down, and at the same time
press the power-on button. The idea is that the camera will try to
autofocus while the lens is extending, hopefully seating the lens
barrel guide pins in their slots.
Fix #5: Blow
compressed air in the gaps around the lens barrels with the idea of
blowing out any sand or grit that may be in there jamming the lens.
Other variations include blowing with a hair dryer in “no heat”
setting, or sucking the gaps with a vacuum cleaner.
Now
we're entering into the realm of potentially damaging your camera in
conducting the fix. Take care when conducting the following two fixes.
Fix #6:
Repeatedly tap the padded/rubber usb cover on a hard surface with the
intent of dislodging any particles that may be jamming the lens. A lot
of people have reported success with this method. HOWEVER, there is
some potential for damaging or dislodging internal components with this
method, such as unseating ribbon cables.
Fix #7:
Try forcing the lens. Many people have also reported success with this
method. HOWEVER, there's obviously some potential for damaging your
camera by using this method. Variations include pulling, pushing,
rotating or twisting on the lens barrel while hitting the power button.
Another variation includes looking for uneven gaps around the lens
barrel, and then pushing on the lens barrel side that has the largest
gap. While doing these, listen for a click that indicates that the lens
barrel guide pins have reseated in their guide slots. If you hear this
click, immediately stop and try the camera.
If this still doesn't fix your problem then the only solution is to get it repaired.
Main support number: 1-800-NIKON-UX , 1-800-NIKON-US
Goodluck..
SOURCE: Lens Error!
my cousin JUST got this error when she took her camera to the beach. (she thinks sand got into it) i brought it to my house and planned on taking it apart. (i'm pretty handy with these things) before i started anything, i tried to make the lens STAY out when it turned on.
1. i opened the bottom where the battery is.
2. i turned on the camera and quickly popped out the battery when it was at its furthest point. (the s210 has a battery latch that pops the battery out on its own. so i just pulled it back so the battery would come out)
3. from there i pulled out the lens as much as i could (pulled slightly, as it hardly moves when off)
4. from there i put the battery back in and powered it on
5. i lens stayed out after it turned on then back off (still giving me the "lens error" screen
6. i powered on 1 more time and the lens went back in. and the camera worked!
you can try this and hopefully it works. (sounds like the gears just got out of place and wouldn't let the lens come out properly)
and if it doesn't work, you always have nikon to call up! :D
hope this helps someone!
SOURCE: Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
SOURCE: Dropped my camera on soft
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
