Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
I hope this helps.
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
SOURCE: I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
SOURCE: blood pressure cure keep reading
Make sure that the cuf is over your artery, there will be a little plastic point in the cuff to show you where it goes, which is right in the fold of the upper arm from the elbow..... Take care.... Guy
SOURCE: I have model 3MD1-CVS (A100/344532)
Hi, Clear all values If you are sure that you want to permanently remove all stored values, hold down the "M" button (the instrument must have been switched off beforehand) until "CL" appears and then release the button. If you do not want to clear the values, press the On/off button. To permanently clear the memory, press the "M" button while "CL" is flashing.
You can download the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
According to information provided in the manual:
Individual values cannot be cleared.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
SOURCE: Walgreens digiital blood pressure monitor model
Since that BP Monitor has a 5 year warranty. Your best bet is to contact HoMedics (the manufacturer) Customer Support @ 800-456-3342. That's assuming you replaced the old batteries with new one's out of a in date package and all are placed properly.
Testimonial: "Thank You I think we might need a new one, over 5 years old."
