Question about Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1
Fujitsu split system
How to remove blower wheel for cleaning
2 Related Answers
seth veloso
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
Anonymous
  • 81 Answers
SOURCE: How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
I need to remove and clean furnace blower.
The entire blower and housing slides out you should find the mounting screws on each side of the blower housing they may be sheet metal screws either on the top or on the bottom. After you remove the two screws the blower should slide out. If you remove the blower wheel from the shaft make sure to tighten the lock screw on the flat side of the shaft. Another trick to pull the blower wheel from the shaft is loosen the lock screw and push the wheel in then clean the shaft wit fine sandpaper otherwise you can cause the wheel to jam up because dirt gets stuck between the wheel and the shaft
Oct 23, 2012 | Heating & Cooling
How to Replace a Blower Fan in an Excursion
Blower Motor
See pics bellow Removal
  1. Disconnect the electrical connector from the vacuum pump (7.3L diesel engine).
  1. Remove the bolts (7.3L diesel engine).
  1. Disconnect the vacuum hose and remove the vacuum pump and mounting bracket (7.3L diesel engine).
  1. Disconnect the speed control servo connector (5.4L and 6.8L gasoline engines).
  1. Remove the bolts and remove the speed control servo (5.4L and 6.8L gasoline engines).
  1. Disconnect the connector.
  1. Remove the blower motor ventilation tube.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: Carefully remove the blower motor so as not to damage the wheel.
    Remove the screws and remove the blower motor.
  1. syo%7eus%7een%7efile=ani_caut.gif%7egen%7eref.gif CAUTION: If the wheel is to be reused, clean the corrosion from the shaft end prior to removing the wheel.
    Remove the wheel from the blower motor.
    1. Remove the push clip.
    1. Remove the wheel from the blower motor
5_7_2012_2_47_23_am.jpg2
5_7_2012_2_48_41_am.jpg3
5_7_2012_2_49_22_am.jpg4
5
6
7
8
9
Installation
  1. Follow the removal procedure in reverse order.
Jan 11, 2012 | 2000 Ford Excursion
My husband cleaned the dryer vent with a brush today and now it is so loud and vibrating. It is a Neptune bought in 1999
Some lint found its way back into the dryer and is caught up in the blower wheel,the speed at which these blower wheels turn any trash that gets hung up will cause a vibration and noise.You are probably going to have to remove the front panel and blower wheel cover to get access to the wheel to clean it out properly. Its fairly easy BUT FIRST UNPLUG THE DRYER remove the screws holding the door,pull out on the front panel at the top where it meets the top,then you will see some screws holding brackets securing the top remove these.then remove screws holding front bulkhead.then you will see the blower housing ,while there make sure blower wheel is not loose on the shaft from the recent vibrating Hope this helps......
Sep 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do I replace the ac/heater blower moter?
Hope this helps....please don't forget to rate...thank you:
Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Disengage the wire harness connectors from the retainer.
  4. Disconnect the blower motor electrical connector.
  5. Remove the motor cooling hose.
  6. Remove the screws and remove the blower motor.
    NOTE
    Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
  7. Remove the wheel from the blower motor as follows:
    • Remove the push clip.
    • Remove the wheel from the blower motor.
Blower motor cooling hose
Blower motor mounting plate
To install:
  1. Install or connect the following:
    • Wheel to the blower motor, if removed.
    • Blower motor and securely tighten the screws.
    • Motor cooling hose
    • Blower motor electrical connector
    • Wire harness retainers
Sep 15, 2010 | 2005 Mercury Grand Marquis
Air condition blower doesnt work in 2003 mercury grand marquis
Removal & Installation To Remove:
  1. Disengage the wire harness connectors from the retainer.
  2. Disconnect the blower motor electrical connector.
  3. Remove the hose.
  4. Remove the screws and remove the blower motor. CAUTION
    Clean any corrosion from the blower motor shaft before removing the fan.
  5. Remove the wheel from the blower motor.
To Install:
  1. Install the wheel on the blower motor shaft.
  2. Place the blower motor in the housing and install the screws.
  3. Connect the hose to the blower motor.
  4. Connect the electrical connector.
  5. Install the electrical connectors in the retainer.
Jul 30, 2010 | 2003 Mercury Grand Marquis
My dryer is taking forever to dry clothes. Very damp and a lot of condensation when I open the dryer. It's model # MDE508DAYW
Good day,
Sounds like the vent system is badly blocked, the blower wheel has stripped off it's shaft, or there is a lot of lint in the blower wheel/lint screen area.
1. Remove the vent hose and see if your getting air moving thru smarty. Maytag moves a lot of air. If O.K. test dryer with vent off for performance. Clean or replace vent hose as needed.
2. Blower wheel sheared on it's shaft. You have to remove the front panel to see if the wheel is loose. Old version had 2 screws on the bottom of the front panel. Remove, disconnect door switch wires and remove. New style (no screws on bottom) requires a putty knife forced on each corner of where the top meets the front. About an 1 1/2 inch in from the edge. Force in, releasing clip, and pulling the top of the front panel toward you. Lift off.
Should the blower wheel be bad, replace but make sure the area between the blower wheel and door filter are cleaned.
Feb 28, 2010 | Maytag Dryers
BLOWER NOISE
Could be a loose blower wheel. It has slipped and touching the sides of the blower housing.
Turn off the power to the nit.
Remove the 2 bolts holding the blower in place.
Make yourself a wiring schematic.
Remove the wires.
Be careful not to touch the capacitor.
Remove the blower housing.
Clean the blower blades.
Spin the wheel to see where it is hitting.
Loosen the set screw on the motor shaft and adjust your blower wheel.
Mar 10, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Noise from the lint vent
idf top mount filter remove screws under filter lid remove nback cover remove 4 screws holding cover and lint housing to back pull housing down and out ..something may be hitting wheel just clean and reassemble ..on inside door filter remove bottom cove remove filter remove screws holding filter/blower cover in place ckd for smae objects clean and reassemble
Sep 02, 2008 | Kenmore 63012 Electric Dryer
Maytag dryer MDGT236aww .......flame ?backdraft? turns off quickly.. How do you get off the blower wheel?
Got it! O.K.
Unplug the dryer. Remove the two screws (Phillips) holding the door hinge to the frame. Remove the other two holding the guides on theother side. Pull the top of the front out and lift it off the clips on the bottom. Remove the brackets (5/16 in screws) (right and left) holding the top down. Notice the direction that those brackets hook into the top.
Lift the top at least a few inches and disconnect any wires you see (light and door switch.) Remember the colors of the wires, and where they go. (The connectors are also different sizes.)
Remove the four 5/16 in screws holding the ring around the basket in place. Remove the ring (with blower suction chamber) and set aside. The blower wheel will now be visible. The blower wheel is held on with a spring clip (pliers) and a snap ring (snap ring pliers). The motor shaft is D- shaped as the blower wheel also was, originally.
If you need to replace the blower wheel, the cover is held on with about eight 1/4 in screws and and one 5/16 in ***** at the bottom. Just fold the wires to the right to get that metal cover out of the way.
While you've got it apart, be sure to clean out the lint in the blower suction area.
Mar 12, 2008 | Dryers
Fujitsu ASU12RLS2 Wall Mounted Indoor Unit Air Handler 12,000 BTU 1 Logo
59 people viewed this question
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
jdthefixer
Muntejaya Ginting
Muntejaya Ginting
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
