Question about Toymax Magnavox 37MF231D 37 in. LCD TV
The master lcd inverter bd. has a red led that goes out after few seconds
The screen flashes but won't stay on,, I have repaced the power supply board and same problem
Terry Dovre
    Filmmaker:
    Uploaded 5 video answers.
  • 181 Answers
Hello, that set has a pair of inverter boards (back light boards) that usually are the cause, you may want to look for bad connections on the transformers and check the little white fuses to be sure their good. But these sets are getting old enough that I've seen the florescent tubes in the display go bad and cause the set to go into shutdown. If you want to try the bak light boards, I found these on E-bay for $20......thanksThe master lcd inverter bd. has a red led that goe - 2f196b76-eae3-4989-b91a-2bf4ff61cb82.jpg
Posted on Aug 14, 2014
1 Related Answer
Abcd
  • 70 Answers
SOURCE: Philips Magnavox 37" LCD Flat
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Posted on Jul 07, 2009
My screen will not come on
Replace it with a new LCD Inverter, you can address the following issues:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
More information in: http://lcdinverter.info
1helpful
Hi i have a problem with my samsung monitor/hd tv, it goes blank in few sec's, you can see picture flashing light directly at screen. I changed Inverter board for a new one, still, nothing changed . One...
First, check to see if you do have 12vdc feeding the inverter bd. The problem can also be bad lamps (worst case). Capacitors look good? No bulging tops?
See example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
1helpful
Re: my 32" Panasonic Viera Lcd-- The red power light comes on for a few seconds, then goes off for another few seconds, then starts blinking. The screen stays black and there is no sound. Bob in LB
id suspect its going in to a shut down mode its likley a power supply problem
but there are inverter boards that can cause this as well
you will probably want to find a servicer in your area to assist with this repair
Red led flashing 6 times
Something is wrong with the power supply of the Hi Voltage section
1helpful
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
3helpful
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
Top Toymax Televison & Video Experts
Ekse
Tom Chichester
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
