And noise stops when door openned
SOURCE: FREEZER SOUNDS VERY NOISY
Fridge problem could be the fan is bad or that it is hitting ice. When the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal.
Thanks.
SOURCE: Noise from fridge when doors are closed.
There is a good chance this is the culprit.
Servicing the Evaporator Fan
In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Good Luck! Buddy777
SOURCE: ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
SOURCE: Our LG bottom freezer refridgerator is 2 years
Sounds like a fan motor inside the machine is failing.
I don't know where you live but in our area, LG has denied anyone but an LG dealer parts. You can check that out but you might use that as a guideline. It's sad here since we can't get parts we don't bother running calls and have little experience with their machines.
