Just like the first comment says the problem is probably something blocking the impeller. I've had the same problem before, and after I cleared it out the fused stop blowing. Try that and if it keeps happening you may need to call a local plumbing company to come and check it out. http://www.kenhaleplumbing.com.au/services
Make sure the impeller is as clean and clear as possible, anything clogging it and restricting its rotation will cause it to blow a fuse. If tis not turning easily and feely most likely the bearing is starting ti seize up.
