Bose Lifestyle 12 System Logo
A
Anonymous Posted on Aug 13, 2014
Bose 5 music center / how to fix display
Led display not working on music system. how do i go about fixing it?
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 24, 2007
SOURCE: The Media Center system doesn't work
Unplug the media center power at the rear power plug. Leave off for 20 seconds. Remove the AdaptIQ headsets plugged into the AUX input. Power the system back up but leave alone for about 10 minutes. After 10 minutes come back and press the "open/close" button the wait 30 seconds or more for the tray to open. Be patient, the media center is processing a huge amount of data and needs time to respond to your commands. It is important to leave the media center undisturbed for approximately 10 minutes after running AdaptIQ setup. After about ten minutes, power down the power back up. You should be ready to go after that.
Anonymous
  • Posted on Jan 15, 2009
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Anonymous
  • 4 Answers
  • Posted on Dec 06, 2009
SOURCE: The display stopped working on my Bose Lifestyle
i did have encounter the same problem!!!! what i did was have the whole capacitor replace ! I didn't bother to have them check beside its will cost you less than $10 this is how a capacitor will look like http://www.allproducts.com/manufacture97/qiyu/product1.jpg . check the ( + )positive ( - )nagative by marking either one on the PCB board before you proceed! very important! good luck
Anonymous
  • Posted on Dec 28, 2009
SOURCE: No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Anonymous
  • 30 Answers
  • Posted on Jan 31, 2010
SOURCE: Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
1helpful
2answers
Display screen led light wont come on
If the display has been gradually fading and is now unreadable, the fault is almost certainly loss of emission of the fluorescent display and it will need a replacement display module fitted (at a Bose Service Centre)
Is there any sign of characters showing in a darkened room?
If it has suddenly gone off, with all other radio features are working as normal, but prior to this the display was bright and clear, and the set has not been subjected to a fall or a sudden sharp impact of some kind, (which can crack the display module and cause it to fail) then the most likely possibilities are; a failed filament supply to the display module, a failed high tension supply rail to the display module, or loss of data feed to the display. It is also possible there may be a fault in the day/night brightness switching circuitry that has shut the display down completely. It is not possible to be more specific without seeing the unit, or even knowing which model it is I'm afraid.
Music centre display is not functioning
The LCD back lighting has apparently gone out or the power supply to it is missing. For more information, please visit my website at audioserviceclinic.com. Thank you.
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
1helpful
2answers
BOSE LIFESTYLE 50 REMOTE CONTROL NOT WORKING
FOR THE BOSE LIFESTYLE 50 SYSTEM (Model P1 - Personal Music Center remote)
You can re-calibrate the remote first by following the steps below:
1. press and hold down on the display screen in the top middle area of the remote
2. After a few seconds the word CAL will appear in the middle and the word SOURCE will appear in the top left area of the remote.
3. Press the SOURCE button.
4. The word KEYPAD will appear in the top right area of the remote
5. Press the KEYPAD button and a small circle will appear in the bottom right of the remote.
6. Press the Circle
This should've recalibrated the remote.
If you need to relink the remote to the system, HOLD down the mute button while having the remote as close as possible to the unit. You will hear a beep . Release the button, after a pause , you will hear the remote beep twice.
This re-links the remote to your system
If the backlight is not working, your options are
1. Spend $349 and get a new one from Bose Or
2.Spend $220 and get a used one on E-bayOR
3. Use your remote with the lights on so that you can see the display :-)...the cheapest way OR Invest in an LED Book light that you can clamp on the remote and use that for your light ($9.99)
Hello I have a bose surround sound system in my house, both inside and out. It appears that only the inside portion of the surround system works and the remote for the outside portion the RC48S2-27 model...
I think we're discussing the Personal Music Center II.
I had to back into the product from the remote model number. Can we assume you also have one of the compatible LS systems (18 or 28 Series II or the 38 or 48) ?
You can go to Bose.com and search for it or register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Bose-Personal-Music-Center-II-Universal-Remotes-manual/id/526dj583/t/2/
The first item in Troubleshooting (page 28) might explain what's happening.
Bose Lifestyle 12 Music Center DISPLAY display light number its not working anymore
I have had problems similar to this on many devices and it is usually a dud LED (light). You can technically de-solder the current LED and replace it but it's not a job for anybody without very good soldering skills.
Check to see if your system is still in warranty as this should be covered. Any electronics repair shop should be able to fix this for you.
Bose no LED display on console
There is a way to send this in for the repair at www.AnyoneCanFixIt.com. Fast service and way cheaper than what Bose quoted.
18helpful
Chris.
3helpful
8helpful
5answers
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
