Question about Sony Playstation 3 (PS3) Console
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
How to make it work on hdmi cable?
Rolenquin
    New Friend:
  • 4 Answers
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Posted on Aug 19, 2014
5 Related Answers
Anonymous
  • 11 Answers
SOURCE: Playstation 3 - No output to T.V
This is not a guarantee but try the following:
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
  • Your video settings are reset and you should be able to choose your input and configure it from there.
Posted on Jun 14, 2008
Anonymous
SOURCE: PS3 HDMI & AV outputs not working?!?!?!?
change the sound output to HDMI? does the sound work on just like a normal tv channel?
Posted on Sep 04, 2008
Anonymous
SOURCE: Playstation 3 HDMI No signal
You have to go into settings on your ps3 and change the output signal to hdmi
Posted on Nov 05, 2008
Anonymous
  • 80 Answers
SOURCE: playstation will not display anything on screen after using hdmi and reverting back to av hook-ups
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
Posted on May 29, 2009
Anonymous
  • 7 Answers
SOURCE: My PS3 hdmi cable does not work
First off, if you want to use the hdmi remove the supplied composite cable from the back of the ps3.
You don't need both plugged in at the same time, and I'm not sure with the ps3 but some video devices will not enable both at once.
Have your tv selected for whatever hdmi input you have it plugged into. They should be labeled where you plug them in.
With the unit in standby, switch off and red light in front, hold the power button by the disc tray for 3-5 second. You will hear it beep, after the initial turn on beep, then you should see a display set up screen.
If you switch back to the composite, you will have to do this over again.
Posted on Jul 06, 2009
I have the system hooked up and it comes on but not o the tv screen do i need the hd cable to make it work it is a flat screen tv please let me know what to do i have playstation 2 already hooked up and...
Are you using the AV connector cable? If so look on your tv for an av channel. Best thing to do though is Try using a HDMI cable. Most tv's recognise when a HDMI cable is plugged in and the tv switches automatically to the HD channel.
Hope this helps.
LJ.
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
PS3 HDMI cable no signal to tv
by new 1ns i had the same problem i bought new 1ns it worked just fine
1helpful
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Playstation 3
Have both the AV cables and hdmi cables hooked up from the tv to the ps3. On the TV Menu goto the av station which is different from the HDMi station...From the ps3 menu screen gotot settings then to video and audio and select hdmi then back to the tv menu and select the hdmi station and the ps3 main menu should be seen and you are all set
57helpful
3answers
AV multi out
when the power is off press and hold the power button until you hear two beeps
New HDMI problem
my brother had this issue with his PS3, he simply went into the settings with the av cable and hooked the hdmi up at the same time and changed the settings from auto to manual.
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Daniel Dollive
Daniel Dollive
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
