Question about Vehicle Parts & Accessories
Gmc envoy brake wiring diagrams
Wiring which wires go were
Nicola Conroy
  • 1,428 Answers
Type vehicle module and the wiring diagrams you need into google and click images. If no luck do same but use word schematics instead of wiring diagram
Posted on Jan 15, 2016
Where is the tail light fuse?
The tail light fuse is under the rear seat on the drivers side.
Jan 17, 2016 | 2003 GMC Envoy
No electrical power to back of car. No brake lights no power to rearendgate window drfogger roof on 2004 envoy xuv.
Sounds like a bad connector in the main harness. You may have to pull the quarter panel trim to check it. You may also need a shop manual with wiring diagrams to know where to look.
Aug 08, 2012 | 2004 GMC Envoy
GMC Envoy 1999 -Brake lights not working (sort of).
bad earth on the bulb holder or the wiring, usually a good clean should sort it out.
Jul 19, 2017 | 1999 GMC Envoy
How do i find the wires and install a brake control on a 2008 gmc envoy
If your envoy even had the option of two package and I am not certin that was an option that would include a brake controler wiring harness then in 2008 it would be tucked up under dash around stearing colum. should be colors like blue white red and orange and black wires in a loom or wraped in black tape. if you have the wires athe controler will have a diagram for GM that will tell you which wire color to conect to what. If not you wil need to find the brake light switch and use the wire from the switched side for on wire and a round a blue "10 wire from the controler to the trailer socket and a power wire from a fress sorce like the battery or a lug that is not being used for anything else. Remember to check and be absoletly sure you can tow the weight both toung and total weight safely with the Envoy before attempting to go to the trouble of doing all the wiring. This warning my seem like something you might want to dismiss, but trust me there is a lot going on when you decide to tow. I mention this when you start talking about putting a brake controler on a lighter SUV that might not be capable of pulling a hevy load. The book might say 7k towing capacity, but realisticly and comfortably you will find it is much less. I do not know off hand the ability of the Envoy, but be tottaly sure before you venture out.
Jun 11, 2011 | 2008 GMC Envoy
Need wiring diagram for Gmc envoy stereo
I dont believe its used in your situation .
here is a rundown
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox or ignition switch harness for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 27, 2009 | 2006 GMC Envoy
Wiring diagram or fuse box diagram-2007 GMC Envoy Denali
Hi there;
Here is the wiring diagram for the trailer wiring for your truck.
Hope this helps
Farrout!
Mar 07, 2009 | 2007 GMC Envoy Denali
Trailer light wiring harness
try http://www.etrailer.com/faq-wiring.aspx. They have very good concise information that might help.
Jan 10, 2009 | 2005 GMC Envoy Xl
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
