SOURCE: I just took my coleman grill out for the season
there may be a problem with the gas regulator,also make sure that the hole in the gas rails are clean form any soot build up
SOURCE: How do you remove the burner part of a coleman
The Coleman website has a pretty excellent list of owners manuals. (Here's the link for the 9921A700)
I believe that you unscrew the burner assembly on the right, which will then let you remove the cooktop to clean inside and re-assemble.
This procedure is not listed on the Coleman website or in the owners manual, however it appears to be fairly straightforward. I'd recommend using some teflon tape on the threads when screwing the burner assembly back on.
