Question about Old Navy Watches
My son just bought a $10 digital watch. It has two buttons on each side: light, mode, start, reset. How do we set the time? I held the mode button in and tried to push other buttons to change the time, but it's not working. Please tell me how to set the time!Thank you!
Lisa Christine
    Scholar:
  • 71 Answers
Use a pencil..hold the mode button in until it starts blinking..then proceed to set the time..hope this helps!
Posted on Aug 15, 2014
  • Yesenia ruiz
    Yesenia ruiz Apr 24, 2016
    Thanks the pencil tip trick worked!
5 Related Answers
Anonymous
SOURCE: How do I adjust date of my watch bought from GAP
Here is the manual from GAP customer service.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user
instructions. Please accept our apologies that no directions were
received with your order.
The instructions are as follows:
Button Functions:
A. Light
B. Mode
C. Start
D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and
the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the
Start button will reset the seconds to 00. If the seconds position shows
more than 30 seconds, pressing the Start button will reset the seconds
to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts
flashing (i.e., second, minute, hour, day, month, and weekend. Press
Start button once for per unit increment, press and hold for 3 seconds
for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
Posted on Dec 13, 2008
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
Posted on Jun 18, 2008
Anonymous
SOURCE: Setting a generic one-button digital watch
I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
Display Date - Press Start-Stop Button in normal time
display mode.
Display Alarm - Press and hold Lap-Reset Button in
normal time display mode.
Cancel Alarm - Press Lap-Reset Button in normal time
display mode to silence alarm.
Hope this is helpful,
George.
Posted on Dec 23, 2007
Anonymous
SOURCE: Can't reset the time on digital watch
I found the solution at http://www.watchliquidators.com/fossildir/Nike.asp
Hold down the button at the top left (the light) for about 4 seconds. The second part of the time will start blinking. I tried this before, I'm sure, but I must not have noticed the blinking and thought nothing was happening.
Once the seconds numbers are blinking, push the top right button (Start/Stop) to move to the hour or minute. Push the bottom right button (Lap/Reset) to change the time. When you're done, push the top left button (Light) again.
Posted on May 20, 2008
Anonymous
SOURCE: lost instructions to set my solo digital watch
I think I have the same watch and was just looking here to see if I could find how to stop the alarm going off every hour! However, I think I do know how to change the time: press the mode button three times (the first one brings up something like the stopwatch, the second brings up what may be an alarm time). On the third press you should get the time appearuing with the seconds flashing on the far right of the display. You can then change the second by pressing the"start" button. To change the minutes or hours, oress the "reset" button until they start flashing and use the start button again. pressing the reset button again will bring up the date to change. keep pressing until nothing is flashing any more and poress mode and it should bring you back to the current time. hope you can follow this and it works!
Posted on Feb 17, 2009
Accutime batman watch time setting
if it is the Batman watch that has a secret screen that lights up when you pushed the bottom middle of the watch face this is what worked for me.I call that secret middle button the mode button.
push and hold that secret button on the watch face until the hour side of the time starts to blink. let go when you see the hour blink and then you can keep pressing to change the hour. to change the minute I let it go back into sleep mode then press and hold the secret button on the watch face and when it starts to blink let go for half a second and then press down and hold that button again and a minute numbers should start blinking. when they start blinking let go and then push once for each minute. it seems once you start one of these cycles letting go for half a second and then pressing and holding the mode button works. you'll have to experiment with how long to let go and then push.
Apr 03, 2013 | Watches
I bought the water resist watch from walmart this evening it doesnt have a name brand on the watch but i think its a casio but it didnt come with the instructions on how to use it, the number on the back...
Thank you for contacting FixYa.
  • There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
  • 2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
  • 3 Press the start button to change minutes.
  • 4 Press the reset button again to switch to hours. You will know it worked when the hour starts blinking instead of the minutes.
  • 5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
  • 6 Press the reset button to switch to the date, starting with the month, and press start to change it.
  • 7 Press reset one last time to switch from month to the day, and again press the start button to switch days.
  • 8 Press the mode button to finish the changes.
  • Sep 14, 2010 | Watches
    Have anAqualite digital watch - and no
    Most digital watches set by holding down the mode or restart button until the display begins to flash. You can then cycle through the display and set on the right time.
    Sep 17, 2009 | Watches
    Lost instructions to set my solo digital watch
    Jan 11, 2009 | Bulova Watch
    Have a casio watch with analogue and digital time.  can change analogue time but not digital time
    Digital time must be set using pushbuttons on watch case sides. One of them is for MODE, another for SETTINGS.
    Mode button usually must be held pushed in for a while to start to work and the digits should start to flash - only then you can start to reset your digital watch using another (settings) button.
    Use small steal pin to push these buttons.
    If nothing happens, you will have to consult your nearest watch repairer as in this case there is a mechanical or electronical fault.
    Rating is very appreciated.
    Jan 05, 2009 | Watches
    GapKids Digital Watch - Need to know how to set
    Light button is A
    Mode button is B
    Start button is C
    Reset button is D
    1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
    2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
    3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
    4) Press D again until the next area you'd like to change is flashing.
    5) At completion of changes press Button B to resume standard time display mode.
    Nov 29, 2008 | Nike Triax Fly WK0006 009 Watch
    I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
    Nov 12, 2008 | Watches
    How to set minutes on watch?
    good evening ! to set the tme ! just press the mode button up to 3 second when the digit are blinking press the start button once to select the digit that you want to chagne ! press the reset button to chagne the digit ! and press the mode button once to back at the normal time! thanks ! god bless !....
    Sep 02, 2008 | Watches
    Setting Bench Watch
    Reset Instructions Bench. (BC0013BR)
    Time and Location
    If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
    Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
    Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
    Alarm
    Hold in the light, start and the reset button for a few seconds a screen will appear
    press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
    Feb 27, 2008 | Watches
    display mode.
    George.
    Nov 06, 2007 | Watches
    Watches Logo
    384 people viewed this question
    Top Old Navy Watches Experts
    Bruce Robin
    Lisa Christine
    Lisa Christine
    Marvin
    Marvin
    Are you an Old Navy Watch Expert? Answer questions, earn points and help others
