Question about Fujitsu Fi-6140 High Performance Color Duplex Scanner
What causes the error code J? - Fujitsu Fi-6140 High Performance Color Duplex Scanner
Scan Aid
    Novelist:
  • 104 Answers
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Posted on Oct 07, 2014
Error code 117 what does it mean
Error code 117 error is the numerical value of the error occurred. The error number is one of the value to identify the error. It holds information about the error, what the possible cause of the error is, the action that caused the error. Error numbers is used to address the errors in the common error code format used by windows and other windows compatible software and driver vendors.
This 117 error code is used by the vendor to identify the error caused. The 117 error code has a hexadecimal number and a technical description linked to it. In some cases the error may have more parameters in hexadecimal format which represents the memory locations where the instruction(s) was loaded at the time of the error. The system.ini file contains the listing of error codes used in Windows operating system and supporting software and drivers..
Mar 27, 2018 | Computers & Internet
Ricoh FT2260 Copier
Try this website to refer to your error codes since the manufacturer of Ricoh uses one set of error codes for their machines. Click here
Nov 30, 2007 | Office Equipment & Supplies
Tip
PF Error Code for Appliances
<p><br /> <p>There is one<b> <i>Error Code that is almost universal to most any appliance</i></b>. The<b> PF or Power Failure code</b> is usually the same no matter what <b>type of appliance</b> or <b>brand</b> you are working with. Even with the fact that this <b>error code is so common</b>, I still see many questions on <b><i>www.Fixya.com</i></b> that are asking <b>what the PF Error Code means</b>.<br /> <p><br /> <p>So now the next question is this.<br /> <p><br /> <p>What causes the <b>appliance to give you the PF error code</b> in the first place?<br /> <p><br /> <p>The most common cause of your <b>appliance giving you the PF error code</b> is a problem with the <b>power coming in from your utility company</b>. Of course if there is an <b>interruption of power</b>, and then the power comes back on you will get the<b> PF code</b>.<br /> <p><br /> <p>Some <b>appliances will give you the PF code also if the power voltage goes low</b>, or goes into a <b>brownout</b> condition. Depending on the sensitivity of the <b>appliance control</b> you may also get the PF code for other reasons such as <b>frequency problems</b> or <b>voltage fluctuations</b> or <b>power spikes</b>.<br /> <p><br /> <p>The other <b>problems that can cause the PF error code</b> can be internal to the appliance.<br /> <p><br /> <p><b>Loose wires going to the circuit board</b> or the control can also be a <b>cause of the error code</b>. If a <b>wire terminal end</b> happens to get <b>corroded</b> or loose, the <b>vibration from the machine</b> can cause slight power problems and this can <b>cause the PF code to be displayed</b>. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by <b>banging on the side of the appliance</b> or <b>slightly moving the wiring harness</b>, to see if you can get the error code to display.<br /> <p><br /> <p>The bottom line about this <b>power failure error code,</b> is that it is <b>power related</b>. Finding the exact cause can be difficult. If you are continually having to <b>reset the appliance</b> then check to see if all of your appliances are giving the same code. This will indicate <b>utility power problems</b>. If only <b>one appliance is giving the PF code</b> then it is probably internal to the appliance.<br /> <p><br /> <p>
on Mar 06, 2011 | Refrigerators
Tally error code 407 system error code11001 how to solve this problam
PROBLEM: Error Code 11001 In Tally is usually caused by misconfigured system files that create registry errors within your operating system. Windows errors can cause program lock-ups, slow PC performance, system crashes, computer freezing and more. CAUSE: Registry errors generally occur when new programs are installed over old ones without the old programs being completely uninstalled. This can cause registry pile-ups and error messages. Another potential cause of these error messages can come from malicious software such as adware, spyware, and viruses.
SOLUTIONS: Scan and repair any missing or damaged Windows registry files using RegCure Pro. After the registry issues are resolved, it is recommended to optimize your PC by removing any spyware, adware and viruses with SpyHunter.
SOLUTION 1: Automatically Fix Error Code 11001 In Tally with RegCure Pro
SOLUTION 2: Optimize your PC with SpyHunter.
SOLUTION 3: Manual Uninstall (Usually Solutions 1 and 2 fix this part automatically)
Feb 29, 2016 | Computers & Internet
How do I fix error 28 on Roku
How to Fix: Error Code 28 Vudu Roku PROBLEM: Error Code 28 Vudu Roku is usually caused by misconfigured system files that create registry errors within your operating system. Windows errors can cause program lock-ups, slow PC performance, system crashes, computer freezing and more. CAUSE: Registry errors generally occur when new programs are installed over old ones without the old programs being completely uninstalled. This can cause registry pile-ups and error messages. Another potential cause of these error messages can come from malicious software such as adware, spyware, and viruses.
How to Fix Error Code 28 Vudu Roku
Nov 25, 2015 | Roku Televison & Video
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
I just got my car scanned and a few codes pop up
Error Code: P0130
Fault:
Oxygen Sensor (O2S) 1, Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
-Wiring harness.
-Oxygen sensor (O2S).
-Engine control module (ECM).
Error Code: P0505
Fault:
Idle Speed Control (ISC) System - Malfunction
Possible Cause:
-Wiring harness.
-Idle speed control (ISC) actuator/Idle air control valve (IAC) valve.
-Throttle motor.
-Throttle valve tight/sticking.
Error Code: P0100
Fault Location:
-Mass Air Flow (MAF) Sensor/Volume Air Flow (VAF) Sensor - Circuit --Malfunction
Possible Cause:
-Wiring harness.
-Mass air flow (MAF) sensor.
-Volume air flow (VAF) sensor.
Error Code: P1491
Fault:
Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
Possible Cause:
-Wiring harness.
-EGR Valve.
-ECM
Error Code:P1607
Fault:
-Engine Control Module (ECM)/Powertrain Control Module (PCM)
Error Code: P0966
-Pressure Control (PC) Solenoid B - Circuit Low
Possible Cause:
-Wiring short to earth.
-Pressure control (PC) solenoid.
-Engine control module (ECM)/Powertrain control module -(PCM)/Transmission control module (TCM) .
Apr 30, 2013 | 2004 Honda Civic
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
Fatal code 0x50
Hi, Hope this helps,I downloaded & manually Translated it from a Russian Website (I speak Fluent Russian)!!
fatal error code 10x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 20xF1 PF PID excess load error. Possible causes : PF Motor failure, PF drive mechanism overload (paper jam, foreign object, insufficient grease, deformation of the Main Frame), Tooth skip of the PF Timing Belt, Improper tension of the PF Timing Belt, Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 30x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Last fatal error code 40x0A CR load position excess load error. Possible causes : CR Motor failure, CR Unit drive mechanism overload (paper jam, foreign object, Change Lever failure), Cable disconnection, Main Board failure (Motor driver failure).
Last fatal error code 50x50 Home position error. Possible causes : Foreign object, Deformation of the Main Frame, Change Lever failure, Paper jam.
Oct 10, 2010 | Epson PictureMate 500 InkJet Photo Printer
I receive an error code for drain error oe code.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 19, 2010 | LG WM2050CW 40 cu. ft. Washer
Fujitsu Fi-6140 High Performance Color Duplex Scanner Logo
429 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Jax Planet
Jax Planet
Richard Schabler
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
