I know about what you are describing. I did this job a few years ago, and as the machine gets older it becomes harder to repair. You probably have water leaking which will cause rust. If you were to do this job yourself you can find the parts on-line for under $100.00 dollars. But because you are planning on having the job done by a repairman the price sounds reasonable. Good Luck Friend.
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean? This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds. Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations. Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing? This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent. Is "Sd" displayed and the wash cycle dial is not flashing? If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds. Is the drain hose kinked or clogged? Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work: NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
SOURCE: maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
