do you know what EVAP is?
it is the gas tank vent system (all of of it) (gas fume controls)
A
containment system. (a smog control system)
I don't know at all what simple means, just what IS ! (tests)
a loose gas cap, reset the code and see if if come back.
bad cap, or the seal bad or the vacuum breaker inside bad(hidden)
that means a new cap is tried next. see why?
first I will post the real manual for you car, (service
Symptom List:
P0442-EVAP LEAK MONITOR MEDIUM (0.040") LEAK DETECTED
(That means a medium sized leak exists)
LEAK AT GAS CAP
VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
VISUAL AND PHYSICAL INSPECTION
VERIFY EVAPORATIVE EMISSION SYSTEM LEAK
EVAP PURGE SOLENOID OPERATION
INTERMITTENT LDP MONITOR FAILURE
EVAPORATIVE EMISSION LEAK DETECTION
GAS CAP
LDP COMPONENT LEAK
Perform a visual and physical inspection of the entire Evaporative Emission system.
Check for the following conditions:
- Holes or cracks
- Loose seal points
- Evidence of damaged components
- Incorrect routing of hoses and tubes
- Fuel Cap gasket seal
---------------------------------besides all that-----------------
5 pages of tests to find the leak
all valves related checks to be sure closed fully.
Purge solenoid tests.
using air pressure leak down testing and using soapy water to find bubbles,
or the smoke machine tests.
I will not cover any of that, as it is a long and tedious process to find the problem if not simple.
anything seen here in light blue can be leaking
https://automotivetechinfo.com/wp-content/uploads/2009/05/EVAP-Schematic.jpg
it captures the fumes and then when driving it burns them up driving.
it is that sample
but if leaks, can be hard to find lacking tools to do the job.
tools, skills, and spare parts
or read this
http://justsmogs.com/2017/04/evap-system-failure-and-diagnostics/
https://search.brave.com/images?q=wiki%20smog%20evap%20system
the only thing simple is find the leak
doing it is a whole over matter, a new gas cap is dirt cheap.
