Question about Microsoft Xbox 360 Console
Black screen with 'system error E74' written on it
Vertical lines all over screen then screen showed system error message appeared. We turned the X box off, left it for 10 seconds then turned it back on. The same system error screen came up.
Posted by littlelinda on
  • 57 more comments
  • mart1n Nov 13, 2007
    system error E74 what can i do with this?
  • Anonymous Nov 24, 2007
    my xbox 360 is sayin error e74 so i went and bought a new av cable still didn't work
  • tony magill Jan 01, 2008
    just got my 360 and after 5-10 mins of play screen was covered with green vertical lines next day i turned on and had single red light and screen displayed error e74
  • Dannyy Jan 07, 2008
    System error. contact customer support. E 74
    www.xbox.com/support (this is the message i received, and i cannot get onto my dashboard as this message on a black screen appears).
  • Anonymous Jan 09, 2008
    a blak error e74 scren shows up
  • Anonymous Feb 23, 2008
    E74:-(
  • Anonymous Feb 28, 2008
    my system did the exact damn thing and its olny liek a year old i want to no if i have to send it in to get it fixed or not or if i have to buy a whole new xbox
    I used this Xbox 360 Repair guide to fix it
  • Anonymous Mar 11, 2008
    same ****
  • Anonymous Apr 30, 2008
    E74 system error i don't know what to do
  • Anonymous May 24, 2008
    i have removed the hard drive and switched my xbox off like you told me but it still does the same thing ... my xbox is only 1 year old and ive tred removing some of the parts and blowing the dust out but it still dos'nt work , please help ... Jake (A MOuLd MeLoN) <---- xbox error E 74
    thanks for listening...
  • werty129 Jun 22, 2008
    Vertical lines appeared, so i shut off my xbox, then turned it back on and error e 74 showed at the bottom of screen HELP!!!!!!!!!!!!!!!!!!
  • Anonymous Jun 28, 2008
    e74
  • Anonymous Jul 01, 2008
    when i plug the av cable in to my xbox 360 the E 74 system error message comes up
  • Anonymous Jul 21, 2008
    Turned my xbox counsel on it flashed green for a little bit then section 4 (lower RIGHT hand quadrent) started flashing red and a system error screen with multiple languages appeared. E 74..... So far I've unplugged everything and took out the hard drive let it sit for awhile then put it all back together. Still flashes red....... I'm wondering how this happened because I haven't played on my 360 for 4 days...... I'm thinking about borrowing a friends AV cable just to make sure I don't have a faulty cable.... I'm worried that it has something to do with the scaler chip.... :(
    Is there anyway at all to fix this WITHOUT having to send in my xbox?
  • x G R I M RG Jul 29, 2008
    i was playing call of duty 4 as normal then Little black dots appeared all over the screen i turned it of left it for about 5 Min's - 10 Min's to cool down a bit turned it back and it came up system error e74 how can i fix this please this is my 2nd xbox my first one got the ring of death then microsoft sent me a new one ive had my new one for just over a year now then this happened also have you noticed this usually happens just after your warranty runs out?
    what is a scaler chip ???
  • swin Aug 12, 2008
    I HAVE THIS PROBLEM HOW DO I FIX IT????
  • Anonymous Aug 12, 2008
    have the e74 error page come up
  • gearwolf353 Aug 16, 2008
    my xbox showed the forth red ring of death and then showed the E74 error how to you fix it
  • Anonymous Oct 13, 2008
    NO SE VE
  • Somil1995 Oct 28, 2008
    4th ring is red
  • minnesotafan Nov 03, 2008
    Red light in 4th player slot. System Error Contact Xbox customer upport in different languages all over the screen and E 74 at the bottom.
  • jmaddox84 Nov 07, 2008
    yeah i have the 4th red light on, with an E74 message.... i even turned it on without anything in the drive, and it still comes up. i unplugged the a/v cables, cleaned them off plugged them in.... still has it. i opened the drive, tried blowing some dust out, but still no luck. would a cd head cleaner work if i put it in there?
  • Anonymous Nov 15, 2008
    it just happened 2 me right now. Is there any way 2 fix this without having 2 send my baby back?
  • Anonymous Nov 17, 2008
    I also received E74. when I boot up the Xbox without the AV cables plugged in it does not get the red ring. I will be trying a new set of cables to see if it fixes the situation.
  • Anonymous Nov 24, 2008
    i have e74 errow also
  • jeffstupar Dec 06, 2008
    Same problem here. First the screen started acting funny with green lines and things. Then I got the lower red light and the black screen with E74 error
  • swanno12 Dec 07, 2008
    what can i dooooooo
  • Anonymous Dec 14, 2008
    my xbox got the system error any way to fix it?
  • Anonymous Dec 17, 2008
    error e74 on screen!
    2 red lights
    2 red lights
  • Anonymous Dec 18, 2008
    red light
    error message but turned back on and now i got freezing!
    2 red lights
  • Anonymous Dec 19, 2008
    error code e74 is on!
    red light
    freezing up!
    error as well red lights on
  • pressurehed Jan 04, 2009
    system error E74
  • Berty131 Jan 06, 2009
    i was playing normaly and black lines came upon the screen i turned xbox of and turned back on then there was a black screen with system error contact customer support in different languages
  • doom12 Jan 27, 2009
    Just bought Skate 2 and after one day of playing it little black dots started showing up and now my xbox is receiving the e74 message DAMN YOU MICROSOFT
  • spotgo66 Jan 31, 2009
    e74 error code cam up
  • Anonymous Feb 01, 2009
    vertical lines appeared, i proceeded to turn the machine off and back on this is when the E74 system error came up on screen.
  • Anonymous Feb 02, 2009
    I have the same problem and my av cables are good checked them with other xbox recieved error code e74
  • Anonymous Feb 13, 2009
    when the xbox comes on one red quarter appears and it says system error in white writing and a black background
  • Anonymous Feb 23, 2009
    system error E74
  • Anonymous Feb 26, 2009
    same as above
  • Anonymous Mar 04, 2009
    went on vacation. unplugged the system before leaving. came back. hooked the system back up and noe it does not work. turrned it on an "black screen with 'system error E74' written on it" posted on screen. tried to clean a/v cables. retried. same problem.
  • TFO Scooter Mar 05, 2009
    i don't understand.
    how can the Av cable be bad if i have been using the same Av cable for three years now?
    Just one day it was like i hate my life and commited electronic suicide?
    And Its funny how in the first three years i had my xbox nothing went wrong but as soon as my warranty ran out, ive had to fix three different rings.
    Is it just me or does it seem like xbox made the xbox to throw up their insides after 3 years?
  • skellclan62 Mar 06, 2009
    their trying to make me pay to get my x box fixed because of e 74 but i am not gonna pay.. i wanna fix it my self
  • Anonymous Mar 08, 2009
    used to be that game would play then turn all crazy blue and green color then shut down then it would now say E 74 lower right piece of ring is red
  • Anonymous Mar 15, 2009
    my xbox has no video at all but i can get sound and thats about it
  • Anonymous Mar 22, 2009
    system error E74, one red ring.
    'system error E74'
  • Anonymous Apr 11, 2009
    My xbox has 1 red ring in the bottom right corner, and the message E 74 on the bottom of the screen. HELP!!!!
  • dekencrg May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com,
  • Anonymous May 11, 2010
    Check this link out and fix this problem --http://solvexbox360.blogspot.com
Anonymous
Ok this is what i have found out The Bottom Right Red light Flashing is
1022 AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
try getting a new av cable should do the trick and i know this post is old But it should help people who are having this problem
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
There Is a bit more info
Posted on Nov 22, 2008
Anonymous
Actually, the E 74 error is a problem with either the scaler chip or the a/v cables, not related to the HDD or DVD at all...
http://forums.xbox-scene.com/index.php?showtopic=484726
Posted on Nov 16, 2007
  • Anonymous Feb 12, 2008
    LOL I love how the "most helpful" comment is not even about the right error.
    The only thing you can do in this case is see if it is the A/V cables, by switching cables with someone else's WORKING 360 or buying new ones, but that's almost a waste of money because if it's the scaler chip, the new cables won't work and you're out the money for them- and you'll still have to send it in.
    Xbox will repair this if it's in warranty, and they're pretty helpful about it- ours said it was out of warranty, even though it wasn't yet but we didn't have the receipt anymore- and they went ahead and repaired it for free for us anyway.
Anonymous
  • 4 Answers
Well i called microsoft and talked to them about this (i have same porblem) i am sending xbox 360 to get reparied but first you should do is take all the cables from the back out, power, internet exct. then put in see if work, if doesnt take out hardrive give it a good clean. if that doesnt work take out hardrive and turn on 360 see if it works if it does its the hardrive that is broken if not its the 360 its self so CALL microsoft and send it to get fix the price is: $132 when you get back you get 12 months warranty and 1 month gold xbox live subscription.
the phone number for xbox support/microsoft is :1800 555 741
Posted on Dec 26, 2007
Anonymous
    Problem Solver:
  • 18 Answers
This is often a hard disk or HD-DVD related error, if you have either of those addons attached try removing them and see if the console works. If that fails your best bet is to phone Microsoft.
http://support.microsoft.com/kb/907536/en-us
Thanks
Posted on Nov 08, 2007
Anonymous
  • 4 Answers
WELL I TRIED PLUGGING INTO AN OUTLET BY ITSELF AND THAT WORKED FOR A WHILE AND THEN I GOT THE MESSAGE...IDK
Posted on Jan 30, 2008
  • Anonymous Jan 30, 2008
    I PLUGGED INTO AN OUTLET TO ITSELF AND IT BOOTED UP JUST FINE...IDK WUT THE PROBLEM IS...MICROSOFT SUCKS...I STILL HAVE THE STICKER ON IT AND EVERYTHING THEY STILL WANT 100...BUT TRY PLUGGING INTO ITS OWN POWER OUTLET...NOT AN EXTENSION CORD OR SURGE MASTER...AND SEE IF THAT WORKS
tekco
    Problem Solver:
  • 16 Answers
Hi, I had the same problem, 1 red led, and Error 74 showing on the screen. I took out the hard drive, and turned the xbox on, and the problem got fixed.
I got my hard drive back on, and the xbox is working 100%
hope this helps.
Posted on Jul 16, 2009
Anonymous
My xbox has also got the 1 ROD. my xbox was a month out of warranty and they gave me a free repair! The E74 is a hardware failure not the AV cable.
If you have E74 and 1 red light, you then take all the cables and accesories out and then take the hardrive out. Then put the cable back in but leave the hardrive out. If it still doesnt work it needs to be repaired. I wouldnt try doing it yourself incase you mess it up!
Posted on Jan 06, 2009
Anonymous
3 red light fix is a bunch of......... Anyways I think if ur box gots the lights then ur forked, go break da bank and buy a new one.....
Posted on Aug 16, 2008
Anonymous
Hey ... my names jake too and i have vertical lines :( i tried what you guys sed but no hope i think im going to take it back to game station before i hawl its *** off to microsoft its a faff on it takes four to eight weeks so hope i still have the reciept lol :)
Posted on Jun 11, 2008
Anonymous
You have to get it repaird thers nothing you can do...
Posted on May 24, 2008
Anonymous
Ok i think i have a soulution for it...now my farther tried the magnet trick...well it worked...for a time..i tried the penny trick and that did work for ****..all it did was zap me. try the ANA chip or A/V cables thats probly the problem. now if that doesn't work yours gonna need to get a new 360 or...microsoft....,.<.< this is what bill gates gets for letin it out a year earlier...but it was worth it,..
Posted on Apr 17, 2008
Anonymous
I just had this problem happen to me, three years after the manufacture date. Never had any problems before this, I must say that despite the bad rep Microsoft seems to get. Customer service is very helpful. I will send it to them , and let them fix it. Your 99$ before tax im guessing gets you another year of warranty. One thing i thought good to mention is that if you have a fancy faceplate or anything take it off and send the box in without it. They might not return your faceplate if something else is wrong with your box. oh and of course keep your cables, and harddrive.
Posted on Mar 20, 2008
Anonymous
I also have the same problem with my xbox360. im getting it repaired dor $100.00. microsoft is sending me a box in the mail for me to put my xbox360 in it and they will repair it and give it back to u in about 4 weeks.
Posted on Jan 04, 2008
Anonymous
Yes the problem is with the scaler chip so ur best bet is to buy a new av cable(no second hand as they may have same problem)if thi does not work contact microsoft
Posted on Dec 22, 2007
Anonymous
Http://www.associatedcontent.com/article/1380695/how_to_fix_an_xbox_360_with_e74_error.html?cat=19
I wrote this article and it has allowed my Xbox 360 to work for over a month now. The trick is to wait the extra day before turning it back on in my opinion. Give it a try!
Posted on Feb 03, 2009
Anonymous
Screen kept frezzing then when i switched off my Xbox and started it again a red light in the bottom right hand conner flashed and i had E74 system error.
Posted on Nov 14, 2008
I have a Sony KDL-46XBR8 Television and it intermittently has vertical lines on the display.
Below is a youtube video I guy did to address that problem. Sony provides a troubleshooting guide at this place, it may be similar to your Vizio model and help you.
http://techin.oureverydaylife.com/sony-lcd-tv-troubleshooting-vertical-lines-screen-35117.html
Nov 17, 2016 | Sony Televison & Video
Scanning and picture malfunction
give a good whak on back of picture tube
Aug 19, 2014 | Sony BRAVIA KDL-46W5500 FULL HD...
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
MONITOR HD2200. I TURN IT ON AND THE SCREEN GOES WHITE THEN A FEW VERTICAL COLOR LINES APPEARS AND AFTER A FEW SECONDS IT GOES BLACK.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out in solving the problem....
May 21, 2011 | Gateway HD2200 LCD Monitor
Camera won't record / film
There is something wrong with your recording heads. TAKE IT BACK.!
Aug 18, 2009 | Panasonic NV-GS50 Mini DV Digital...
A white line has appeared on my desktop only
Two inch vertical line appeared.It sometimes is on the left and sometimes moves to the middle. It is only on the desktop.
Feb 20, 2009 | Microsoft Windows XP Professional for PC
Sony Wega 27in Randomly Has Block Box Appear On Screen
this means the TV having picture upper part of the screen. problem may be -15 V to vertical deflection ic suddenly gose off and system control gose to stand-by mode resolder vertical out ic , -15 v supply line from the fly back and system control .
Jan 15, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Clearing message after "replace photoconductor kit" message came on
To reset the photoconductor page count:
  1. Turn off the printer.
  2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
  3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
  4. Release the buttons when you see either of these messages.
  5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
  6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
  7. When the display shows CONFIG MENU again, power off the printer.
  8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
    The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
    1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
    2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
    3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
    4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
    5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
    6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
    7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
    8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
    9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
    10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
Jul 28, 2008 | Lexmark E342n Laser Printer
My screen showing a vertical line
Replace the laptop under warranty. No point trying to fix the error and voiding the warranty.
May 25, 2008 | Compaq Presario Notebook
Microsoft Xbox 360 Console Logo
13,927 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
James Bradburn
James Bradburn
Lee Hodgson
Lee Hodgson
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
