Televison & Video Logo
A
Anonymous Posted on Aug 14, 2014
The volume does not stay constant
Volume does not stay at constant level. watching a program people talking at correct level, then music, action scene, or chase scene volume gets way to loud. we are constantly turning volume up and down watching same movie or program.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Aug 14, 2014
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986432
Points
237762
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
5 Related Answers
Robert Johnson
  • 395 Answers
  • Posted on Jan 20, 2008
SOURCE: Background sounds
go to the sound menu and shut off the BTSC-sound, SRS Panoramic 3D sound and place it into stereo.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: Sharp Aquos LC-26D4OU HDTV volume adjustment problems
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Anonymous
  • 203 Answers
  • Posted on May 04, 2009
SOURCE: sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
Anonymous
  • Posted on Aug 17, 2009
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Chi Chu
  • 8457 Answers
  • Posted on Dec 20, 2009
SOURCE: Red rash that shows through in dark scenes. Can't
Might cause magnatic field,form.Try unplug,replug the tv an hour,move it couple inches to the left or right might help.
Master volume not registering at correct level. Profx12
This unit will require an amp. I have set up several mixers and I
do not watch output level numbers, you can get desired volume using amp. It does no good to drive input levels high output levels high and the turn down amp. Lower your inputs so no light flashes set master gain to -6 output and then raise amp volume. I have set up 16 mic mixer set individual levels and the feed to main mixer and controlled levels with one fader. I have taken mixes from main mixer to another mixer to control audio on video feed. A good band does not let member's set their levels . the audio person set levels, bad bands have members to set own level with resultant a mess that gets louder and produces sub par event. Remember good bands sound good and bad bands only sound louder, and bad
tip
How do I make my iTouch Louder
<p>He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music. <br /> <p><br /> <p>1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow. <br /> <p><br /> <p>2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings. <br /> <p><br /> <p>3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music. <br /> <p><br /> <p>4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch. <br />
on Aug 05, 2011 • Computers & Internet
How do I increase JUST Alexa's voice and not the music?
Arcing sound
laouli,
check the program you are using to play the sound if the volume is at an audible level, next check your *Master Volume* settings bottom right corner on the desktop *windows*. if this does not work you need the correct audio driver,
please advise your Operating system (windows or Mac)
Version *64 or 32* bit.
Make and Model of the Laptop
1helpful
Audio problem streaming media via ROKU and RCA players. Constantly have to adjust volume to hear them talk, but then the music/sound effects blast you out.
It sounds like you're using a set of stereo speakers to play a surround sound output. I would try going in the TV menu and turning off surround sound
Vsx-52o when watching dts or any good movie the low sound talking you cannot hear well unless the sound level up to 55 or more ,but when the action or music starts it blows your head off its that loud...
That could be one or both of two things at work here.
One is a failing or mis-configured center channel. Crack the manual and make sure the speakers are all workign at the desired level with test tones.
The other is dynamic range (ratio of loud to quiet sounds). In a silent listening environment with the volume set at a comfortable level for the loudest sounds (like during the beginning of some movies you get that THX sound logo or some other audible but loud musical intro, THAT's what you adjust for) the relatively quieter moments would still be audible. Add normal background level sounds of a real-life environment and you can lose the quieter sounds and dialog.
In a perfect world and in accordance with the engineer's decisions, the widest dynamic range is the correct way to enjoy a given recording or movie.
http://en.wikipedia.org/wiki/Dynamic_range
Experiment with the DRC (page 34) for each soundtrack to see if compression might work better.
Volume increases on its own intermittently
When the volume increased did the display show it doing so as if someone was turning the knob?  I mean did the volume go from like level 15 to 30 or did the unit's level stay constant while the audio volume increased?
Were you alone or sharing the room with a jokester who has a universal remote?
Does this problem occur when the batteries are removed from your remote?
Are you sure the 'volume up' button on the unit itself is disengaging properly after being pressed?
Volume Control
I had the same issue, there is a Late night mode on the remote that minimizes the volume of a loud scene so you don't have the constantly adjust the volume. Works great if you are trying to watch a movie while others are trying to sleep.
Sony STR-DE475 - Sound levels dropping
When did this start? Did it ever work right?
How's the sound from your TV speakers by itself and from DVD? The same? Problem's in the TV.
If it's just the receiver doing it from both sources that's where we start.
Check the settings for dynamic range (ratio of loud sounds to soft sounds) in both your receiver and your cable TV tuner. Many devices have a setting sometimes called "MidNight Mode" to be used in the event you're listening while someone else might be sleeping or otherwise would be disturbed by the TV volume.
The assumption is that you will turn the TV down but that normally means you would lose the quiet programming in the background nosie of your home. Through the magic of dynamic compression the quiter sounds are raised to audibility while loud things like explosions and fanfares will be limited in volume. Depending on the design and whatever the broadcaster is doing to the sound themselves this could be anywhere from pleasingly effective to aggravatingly inconsistent with odd variations in the levels.
Hope this helps.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
