Question about Refrigerators
Move the feeler arm above the ice bin to the up(off) position.
Below is a link to a GE side by side refrigerator manual. It may not be the exact one for your fridge. Page 20 of General Electric Side by Side Refrigerator Owner Manual...
Posted on Aug 14, 2014
SOURCE: Ice will not dispense GE model GSL25IFRF BS
well if you trouble shoot the board at the back to see if you are getting voltage if you are then use a jumper on that conenctor and see if the auger motor runs or remove auger motor and check voltage there while pressing the lever for ice usually 100% of the time that board controls everyhting water and ice
Posted on Nov 18, 2008
SOURCE: Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Posted on Jan 30, 2009
SOURCE: THe ice maker has stopped working in my GE refrigerator.
change icemaker
Posted on Apr 06, 2009
SOURCE: GE Frig model TFX20JRBK ww with icing on freezer
I would suggest fixing it . You only have 2 parts in the defrost system . A timer , and the defrost heater which comes with the bimetal , pt . # WR51X10031 .Most probable , is the defrost heater . You will need to remove the rear inside freezer panel , and defrost the coils with a hair dryer . After defrosting , 2 screws hold each ( 2 ) heater on , ant the defrost thermostat , just clips onto the top of the coils .
Posted on Nov 18, 2009
Oct 06, 2015 | GE Refrigerators
Aug 14, 2014 | Refrigerators
Jan 18, 2012 | GE Refrigerators
Mar 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Feb 18, 2010 | GE Refrigerators
Dec 20, 2009 | Refrigerators
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 02, 2021 | GE Refrigerators
Feb 25, 2021 | Refrigerators
118 people viewed this question
