If unplug 24-48 hours, it works again for a couple of days, then quits again.
SOURCE: GE Profile Artica Refrigerator
OK, it sounds like you have a defrost problem. When left unplugged for a few days the frost melted off the evaporator (the cooling coils behind the freezer wall) but after you ran it again, the coils blocked the air flow again, usually happens after a week or so, depending on # of door openings, humidity in home, etc. Most likely you have a burnt out defrost heater.
SOURCE: kenmore fridge stopped cooling
sounds like its freezing up on you. check the drain outlet and make sure that its clear. also i would replace the defrost timer on this unit because its suppose to bring on the heaterfs to melyt the ice so thaat yoiu don't have to. they are around 30 mdollars at the appliancew repair store and all you need is the model number and serial number for the uit. after you get it it's either on the very top of the refrigerator section or in the very back. It has 4 wires going to it. good luck.
Your defrost system is bad. Replace the defrost thermostat and defrost heater in the freezer.
SOURCE: freezer and refrigerator doesn't cool properly
Sounds like a main control board bad . A model number would help .
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
