Hi Tech support, the paper tray not detecting paper, please help thanks
SOURCE: DP-1820E - Contact Your Dealer - Printer Error E02-01
E02-01 refers to the tray 1 lift motor either you have a bad motor or there's a problem with your main board. good luck
SOURCE: Software for Panasonic DP-1820E
Google "PANASONIC DP-1520 PRINT DRIVERS" or go to:
http://www.panasonic.com.au/support/downloads/file_type_results.cfm?fileTypeID=1&productCategoryID=28&productID=387
It's Panasonic Australia, but its the same ones I use. Use the GDI print driver to avoid any problems. Make sure you get the right one for your OS (ie WIndows XP, etc)
SOURCE: My panasonic Dp-8020P is giving
u have to short the front door interlock switch as it is not working.it happens in this model quite often.remove the front cover and door .the short the interlock switch with a wire .that's it ,if u can find one then better to replace it.
