Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Canon sd750 lcd screen is very dark but can still see pictures and take pictures
Mikhail Abraham
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
The bulb inside of it is shot
Posted on Aug 13, 2014
1 Related Answer
darntoothysa
Thomas D.
  • 489 Answers
SOURCE: LCD screen dark on Canon SD750 camera
Hi
If you can't take new pictures (they are totally black) but you can see old pictures, then either the lens aperture is stuck closed or your CCD is bad. Either means that you need to replace the lens of the camera.
You can look online for a defective camera and make one good one out of the two, but it's difficult to find one with a good lens!
Don't bother going to a store or 'service center' though you can if you would like to verify what I'm about to say. They won't know anything about camera repair, and will want to charge you $150 or more for the repair if they say they will do it. If they do take on the repair, all they will do is send it to Canon which you can do yourself for about $150.
There are AFFORDABLE digital camera repair businesses online, I know, because I own one! We can replace your lens for about $75.
Good luck with your repair,
Thomas D.
Owner; Darntoothysam com
Posted on Apr 13, 2009
Canon Powershot sd750 screen completely not working
If you're up to doing the replacement yourself, you can order a new LCD assembly here. If not, you can take the camera to a reputable camera shop and have a trained professional do the replacement. A third alternative is to buy a new camera to replace the five-year-old SD750.
May 13, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
Thw pictures are coming out black
should be a brighness setting you can adjust in the settings menu
Apr 30, 2012 | Canon PowerShot SD750 / IXUS 75 Digital...
I have canon sd 750. its lcd gets black. Shows pictures etc but view finder remains dark. display is zz. what to do?
Look for DISP or DISPLAY button in the lower-right corner of the back of your camera. Press this once while the camera is turned on. The DISPLAY button manually turns the screen on and off. This is to save battery power for extended use. You would then use the optical viewfinder in its place.
Oct 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
When i turn on my sd750, the back screen appears dark (cannot see what the camera is point at and when i take the picture, it is black ... in the past i was able to retify but putting on and off a few...
There usually is a button on the camera which will affect the LCD operation. On these Canons usually it is marked with a small monitor icon or it has "Disp" next to the button. This is on the surface of the camera and not in the menu. It will also be in the menu, but since you cannot see the lcd display, then I assume you have to try to use the buttons on the camera.
Dec 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon SD750 camera
The problem could be that the room is too big. Try taking pictures closer to the wall, so the flash can bounce back more effectivly.
Oct 21, 2009 | Cameras
Hi
Thomas D.
Apr 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Dark stain on display screen
it should be a stain spot on the camera lens..try taking it to an authorised service point and have it cleaned
Dec 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Black spots on the lcd display
I also have a brand new canon powershot sd750, with the SAME PROBLEM!! what IS THIS?!?
Apr 18, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Paul Green
Are you a Canon Camera Expert? Answer questions, earn points and help others
