How do I pick up my messages from my mitel 5330 IP Phone from an external phone?
SOURCE: voice mail password reset without current number mitel 5207 ip ph
What voicemail do you have? Login to admin mailbox or login to phone system if you have Embedded voicemail.
SOURCE: HOw do you change the time on the mitel 5330 IP
You cannot change the time from the phone. Your system administrator must change the time in your PBX. If you have the latest version, you can have your PBX sync with an internet time server and will never have to update again!
SOURCE: how do i configure the
Either your on-Site system administrator, or your vendor will have to
make the change. This is a system wide setting, not just your phone.
Once the mailbox is set up in the system, dial the access code and the password (default is 1111). Follow the prompts... you are not complete until the guide tells you are.
Good Luck,
Mark
SOURCE: dhcp: Discovery Option 128 missing.
Option 128 tells the phone where the phone system is. A linksys router isn't capable of giving this option out. Where is the telephone system? Is this a teleworker phone? if TW phone, press and hold the 7 key while booting the phone, and type the teleworker server IP address.
I recommend you contact your administrator or system vendor for guidance.
SOURCE: How do I change my
Log into your mailbox. Press U(8) for User Options. Press G(4) for Greeting. Listen to the prompts.
