Display shows Fault F4 which list says in an IGNITION fault. What can be done
Not a problem. I have noted that the F4 Ignition fault you are getting is with a Glowworm 18si boiler.
This relates to the burner system and will need a gas licensed technician to fix it.
I am providing you reference to an Installation and service manual to help you understand the likely fault but under no circumstances is this an invitation to attempt to fix the fault unless you are a qualified gas technician. Refer page 37 in the manual.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/24ci-18si.pdf
SOURCE: F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
SOURCE: Whirlpool ADP5966 fault code F8
just choose another prog setting and hold the start button in for a few seconds.
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
SOURCE: please could you tell me what an F4 fault is on a
f4 fault on a whirlpool ADP5966 dishwasher means (1)Not draining or water level sensor not working . there might be blockage in the drainnage . find
the blockage and remove the blockage. Other problems can be wiring or problems with the control board.
hope this helps pls do let me know
Hi Frank Daykin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please clarify which dishwasher you have and its model. Dishwashers do not normally have an ignition system so it is very unusual error description.
Sorry Sam...something went wrong with the posting (first time for me!) because my question was concerning a Glowworm 18Si sysstem boiler ingintion.
