Question about Kyocera FS-9130DN Laser Printer
What can i do for error code 5300 on kyocera 9130 printer
Doug Sneddon
    New Friend:
  • 60 Answers
Broken cleaning lamp wire While the cleaning lamp is on, the broken cleaning lamp wire detection signal is detected for 2 s continuously.
Id look at replacing the drum unit
Posted on Nov 25, 2014
Install MK Kit Kyocera FS-9130 How to reset MK Kit Counter
you can reset the counter but on the falcon engines if you go past the maint. cycle they will eventually fall down and print solid black copies.
Feb 04, 2016 | Kyocera Office Equipment & Supplies
Kyocera fs4100dn with error code f245
The proviso of whether it's B or 8 holds.
http://www.copytechnet.com/forums/kyocera/82182-what-error-code-f24b.html
Feb 10, 2015 | Kyocera FS-4100DN A4 Mono Laser Printer...
Kyocera fs9130dn
Jul 24, 2014 | Kyocera Office Equipment & Supplies
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Nov 07, 2013 | Kyocera Mita FS 3800 Laser Printer
Printer kodak 5300 says error code 6203
printer needs to be replaced
call kodak at 18004216699
Feb 08, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 0150:0008438
bad engine board... replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
May 14, 2009 | Kyocera Mita KYOCERA/MITA - FS-4000DN Mono...
OfficeJet 9130 all-in one
I updated the HP 9130 firmware and encountered the same problem. I turned off the printer, removed all the printheads and the cartridges, closed the printer cover and then turned on the printer again. After seeing an error message on the printer screen concerning the missing printheads, I opened the printer cover, replaced all of the missing printheads and the missing cartridges and then closed the cover. The printer then aligned printheads once as is expected after replacing the printhead and cartridges. Thereafter, it worked normally. I do not know why this procedure worked and if it will work in every case, but for now, it seems to have worked for me.
Apr 10, 2008 | HP OfficeJet 9130 All-In-One Thermal...
Kodak Easyshare 5300, fatal error 3812
That's an error with the ink. Try updating the firmware on the printer. Here is the link to the latest firmware from the Kodak website.
http://www.kodak.com/global/en/service/downloads/dln_ekn033540.jhtml?pq-path=9106
Dec 25, 2007 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kyocera FS-9130DN Laser Printer Logo
461 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Kyocera HP Expert
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
