How to hook up DVD player to 19' led HDTV
Toshiba SD4300 dvd player
NoName Jack
  • Televison & ... Master
  • 1,150 Answers
The modern way is to buy a HDMI Cable
Plug it in to the HDMI Port on back of DVD Player
Plug the other end into spare HDMI Port on LED TV.
Put in a DVD & hit Play
Use remote control to select HDMI port on LED TV
If it does not have a HDMI port then you need a converter box which picks up the Red & White (sound) & Yellow (viideo) and converts to HDMI standard.
Posted on Aug 13, 2014
5 Related Answers
Anonymous
SOURCE: Toshiba SD 3960 DVD player
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
Anonymous
  • 15 Answers
SOURCE: toshiba dvd player not reading Taiyo yuden blank media
It is probably the player that is dirty or scratched, You will have to buy a lense cleaner kit usually no more than $30, similar to cleaning the heads on a vcr. If that does not work then you will prob have to get it professionly cleaned.
Posted on Mar 14, 2008
SOURCE: JVC DVD player problem
press and hold I\P button from remote control
Posted on May 16, 2008
zimcloud
  • 135 Answers
SOURCE: Unlock - DVD player -TOSHIBA model SD-P91SKN
Go to; www.videohelp.com input your make and model, hit search, scroll down, look to right of screen for 'Hacks" that is what you are after.
Posted on Jun 27, 2008
Anonymous
SOURCE: toshiba 220e dvd player
http://www.dvd.reviewer.co.uk/info/multiregion/
Posted on Oct 29, 2008
How do you eject the DVD
I you can't do it with the Remote control, you might be able to do it on the TV itself.
I'm not positive about this, but there should be a button on the back outer-edge of the TV that may control the DVD player.
If not, here is a link to Download the manual. Scroll down & click on 'Guides + Info' and then the download link.
http://www.us-appliance.com/pledv1945a.html
PLEDV1945A Proscan 19 LED 720p HDTV with Built in DVD Player
Good luck.
Andrew
Feb 24, 2015 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Connection tv
The regular RCA cable would do the job
Dec 29, 2013 | Toshiba SD-K620 DVD Player
Dvd player won't read any disks and when i put the dvd cleaner in it the tv says no disk
Either its sled motor [the motor that spins the disc inside] or the laser pickup unit might be faulty. Check it.
Nov 02, 2013 | iSymphony " 19"" Class - LED - 720p - 60Hz...
Connecting dvd player to old tv
Turn off the progressive scan and then connect. Also let me know the ports available on the TV so that I can check whether it requires any converter to make the connection. Thank you.
May 05, 2012 | Toshiba SD4300 Progressive Scan DVD Player...
Hooking up dvd player to Toshiba DPL 52" HDTV
Send the viseo to the Tv using composite or component input and send the audio ( red and white RCA audio ) to the BOSE.
May 13, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Dvd is grainy picture
You can use your old on, but I am guessing it doesn't have progressive scan. If it does, make sure to hook it to your TV using a component cable.( RED GREEN BLUE ) Then you will have to hook the audio up seperately with a standard red and white RCA cable. Do nt try to use a standard RCA video cable in the place of a componenet cable. Once you have the compnent (RGB) cable and RCA (RW) cable hooked to the TV, check the DVD menu and make sure it is set to Progressive Scan. If you want the best picture for your HDTV. I highly reccomend a blu-ray disc player. That is the highest quality. There are some prety good upconverting DVD players out there. They take the 480p signal and upconvert them to 720p, 1080i, and 1080p. These have HDMI outputs and connect quickly and easily to the TV you have. Most of them can be purchased for less than 100 bucks. But this would be your second best option. Before you shell out 400 bucks on a blu-ray player, go to a rental company and rent a blu-ray player. Once you see the quality of blu-ray, I think you will run out and buy one!
Jan 10, 2009 | Toshiba 19HLV87 19 in. LCD HDTV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
