Question about Sony ICF-C318 AM/FM Clock Radio ( White )
How to use the sleep button - Sony ICF-C318 AM/FM Clock Radio ( White )
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
Location sleep button
Usually the sleep button and the power button are one and the same. If you are running Windows, you can go into the control panel. select power options and then choose what pressing the power button will do.... you may choose hibernate, sleep or shutdown. If I knew the model of your computer and operating system, I could provide a more detailed solution.
Microsoft Digital Media Pro Keyboard sleep mode
you can disable the sleep button
https://techdows.com/2013/02/disable-sleep-keyboard-button.html
1. Open Control Panel>Hardware and Sound >Power Options> On left of the screen click on "change when the computer sleeps"
2. Click on "Change advanced power settings", scroll down a bit
3. Expand Power buttons and lid> double click on "Sleep button action", click on Sleep setting and choose "Do nothing".
11helpful
3answers
4helpful
My remote does not have the sleep timer button.
Open cover on the bottom part of the remote SLEEP button is there.
12helpful
2answers
Can I disable Sleep Button
If you are using Vista ... control panel.... system and maintenance.... Power Options. On the left there is an option for "Choose what the power buttons do" You can disable the sleep button there. C'mon Compaq... get a brain!! Who's dumb idea was it to put the sleep button there?
2answers
Remote controler
press picture/sleep button. use the buttons on lower left to set. press arrow bouttons to set time and hit enter (middle button)
Sleep button
u have to aigain press ur sleep button tehen he will be wake uo
or power off ur pc & restart its
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Sleep
THe only way to use the sleep function is if your tv has a sleep function. If not then that button won't deep anything for you. Otherwise you should just be able to hit the sleep button.
Sony ICF-C318 AM/FM Clock Radio ( White ) Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
 Francisco Mauricio...
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
