Question about Kenmore Dryers
Why does my dryer flash f01 on kenmore dryer model # 110c875
Model # 110c875
4 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Our Kenmore Elite he5 steam dryer has an error
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: HE5 Electric Dryer: i have a kenmore elite smartheat dryer, but when i...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Posted on Sep 30, 2010
TheMobilian
Dan Webster
  • 8220 Answers
SOURCE: The dryer flashes F01 when
Control failure. Replace the control electronics:
Failure codes
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 24, 2011
ned_san_jose
Ned Halaweh
  • 240 Answers
SOURCE: Kenmore electric dryer code f01 what does this
Usually in my experience the control board is the problem.
You will need to replace this and your problem will be fixed.
It's very easy to change yourself, don't hire a repairman.
I posted the exact board on my website repairbeware.com.
This site will also give you good info if you need to hire a repairman to do the job. Hope this helps :)
Posted on May 27, 2012
Dryer comes on but gives a code
f01 is a bad computer board,you can try unplugging it for a few minutes and see if it resets,if not the board is bad,next time send the full model number off of the dryer so whoever helps you can look it up,kenmore doesn't make anything the only way to tell what you have is from the model like if it starts with 110 that's whirlpool,417. is frigidaire but you have a bad computer board in the dryer
Nov 08, 2017 | Kenmore Dryers
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
My kenmore dryer he2 is showing F-01
F01 is failed main control board.
Sometimes, however, it's caused by a power surge. If unplugging it for five minutes and plugging it back in doesn't clear out the F01, then you need a new control board
Oct 22, 2014 | Kenmore Dryers
F01 Error
F-01 flashes when there is a primary control
failure. Replace the machine control electronics.
from http://www.advantagesupplyfl.com/WhirlpoolDryerFaultCodes.html
Jan 08, 2014 | Whirlpool Dryers
What does F01 code mean?
The F01 error code indicates a failed primary electronic machine control board. This can be caused by a glitch or power surge through the power lines. Try unplugging the dryer for 5 minutes and see if the code clears. If it doesn't, then you will have to replace the electronic machine control board,
Dec 17, 2013 | Kenmore Elite HE4 Electric Dryer
Has an f01 error
The error code f01 indicates the primary control board failure. Before you replace that board I suggest that you unplug the dryer for 2 minutes then see if the error come back. If it does replace the board part number W10110641.
May 13, 2012 | Kenmore HE5 Electric Dryer
Model# 11087721700, with f01 error fix
Dryers Logo
1,825 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
