2005 Chevrolet Colorado Logo
A
Anonymous Posted on Aug 12, 2014
P0601 code c0899 u1064 what do they meen
The truck shuts off and losses all power then you what 2min and it will start again.
Randy Ohler
Level 3:
  • Chevrolet Master 14,585 Answers
  • Posted on Aug 13, 2014
Randy Ohler
Chevrolet Master
Level 3:
Answers
14585
Questions
8
Helped
3942065
Points
39683
601 is internal memory code.
899 is power take off code, Dealing with loss of power.
0164 is loss of communications. Again this could be loss of power.
Clear the codes. run it down the road for a while , check codes again.
If they come back, you either have a bad wire some where or the control module is bad..
3 Related Answers
Anonymous
  • 1263 Answers
  • Posted on Apr 21, 2009
SOURCE: Vehicle shuts off and will not start back up right away. P0601
what that means is your engine goes into protection mode and shut's off this is mostlikel;y do due to low coolant level or low oil level/pressure. have this checked by a qualified tech. diagnostic equipment must be used to clear the code after the problem is solved in order for your vehicle to run properly
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Sep 23, 2010
SOURCE: I have a vortec 350 setting a trouble code P1345,
p1345 is a crank/cam sensor correlation fault possibly due to a
failure in this solenoid.other possible causes include engine timing
Anonymous
  • 1010 Answers
  • Posted on Mar 17, 2013
SOURCE: what does code c0899 device power circuit low mean?
You have a stability control issue, take it to the garage, to check it out which sensor is at fault
What's the code u1064 mean in a 2006 pontiac grand prix
What is code U1064. ... The code U1064 is a loss of communications with DIM, usually caused by loss of power to the Body Control Module. It can be caused by an ignition switch going bad or loose battery connections
LOOSE BATTERY TERMINAL
Car shuts off while driving and says starting disabled Service throttle. Please Help! Check engine code says P0601
Definition of Diagnostic Trouble Code P0601 Category: Powertrain Definition: Internal Control Module Memory Check Sum ErrorNote: This definition of P0601 is applied to all manufacturers
2answers
Chrysler sebring code p0601
Hi Again,here's another link,to your P0601 code. P0601 OBD II Trouble Code
What does the ecm fuse under the hood of my colorado 2005 i5 look like
These should be labelled in the fuse block. If not, shop manual should help.
1helpful
Check engine light codes
the c0899 is a low battery voltage and the u1064 means communication is lost with the bBody Control Module. The u1026 is also a communication problem and the p0449 is an emissions problem, around the venting of the fuel tank. Sounds like several different unrelated problems.
U1064
U1064 - Loss Of Communications With DIM
Problems with 2003 chev. blazer code showing p0601
Sorry to say the code is for an internal problem with the computer.
It could be a loss of power for the memory, or a faulty computer.
If it looses power, it has to relearn the basic settings much like a digital clock switching to 12 noon when you unplug it.
The computer gets power from the battery for the memory part and from the key switch for everything else.
The code will set if you disconnect the battery with the key on.
1helpful
I took my 2004 Blazer to get a diagnostic check. Two codes came uo U1064 and U1096. What are some solutions to fix this problem? The instrument panel lights stay on after the car has been started and will...
U1064 - Loss of Communications with DIM (Dash Integration Module)
Here is some TSB
Refer to Data Link Connector (DLC) Schematics
Circuit Description
The class 2 serial data line communicates information between modules. Each module connected to the serial data line is assigned a recognition code, or address. This code is used in order to identify which modules are communicating. Modules communicate with each other by periodically sending state of health (SOH) messages. When the ignition switch is in RUN, each module communicating on the serial data line sends a SOH message every 2 seconds. This ensures that the system is operating properly. When the dash integration module (DIM) stops communicating on the class 2 serial data line, the SOH that is normally sent on the serial data line every 2 seconds disappears. The module, which expects to receive that message, detects the absence of the message. The module in turn sets DTC U1064 associated with the loss of SOH of the DIM.
Conditions for Setting the DTC
The module does not receive a state of health (SOH) message back from the DIM. The module retries the request 3 times, and then sets DTC U1064.
This DTC only sets if U1300 or U1301 is not current.
Action Taken When the DTC Sets
DTC U1064 is stored in the module.
The module uses the default values for the initialization data. This DTC does not cause driver warning message to appear.
Conditions for Clearing the DTC
This DTC clears (status changes from current to history) under any of the following conditions:
The module detects a state of health message from the DIM.
At each ignition cycle.
A history DTC clears after 50 consecutive ignition cycles if the conditions for setting the DTC are no longer present.
Current and history DTCs may be cleared using a scan tool.
Diagnostic Aids
DTC U1064 does not normally represent a failure within the module.
When loss of class 2 serial data communication DTCs (DTCs with the letter U as the prefix) are stored as history DTCs, know all possible serial data DTCs set in each module before diagnosing the serial data line.
If U1064 is stored in the module memory, inspect for the same DTC stored in other modules capable of storing this DTC.
If the DTC is a history DTC, the problem may be intermittent.
Test Description: The numbers below refer to the step numbers on the diagnostic table:
U1064 is the result of loss of communication with the dash integration module (DIM). Note that other modules on the class 2 serial data line may also set U1064 if the DIM is not communicating with the serial data line.
Clear all DTCs after the repair procedure is complete.
Step
Action
Value(s)
Yes
No
Did you perform the Data Link Communications Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Data Link Communications
Use a scan tool in order to attempt the establish communication with the dash integration module (DIM).
Does the scan tool communicate with the DIM?
Go to Step 3
Go to Diagnostic System Check - Body Control System in Body Control System.
Inspect and repair the class 2 serial data line CKT 1807 (PPL) for intermittent connections. Refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
Is the repair complete?
Go to Step 4
Turn off the ignition switch.
Reconnect or install any connectors or components that were disconnected or removed.
Turn on the ignition switch.
Clear any DTCs.
U1096 - Loss of Communications with IPC
The computers on the Chevy require a certain voltage to operate and if the voltage drops below a preset limit then it will tripper a loss of communication with the other modules, this drop in voltage happens when the car is started and the draw on the starter uses a large amount of amperage. I suggest to check power/ground in the instrument cluster and if good do a resistance test on Data wire.
If your car is not experincing any messages like "service vehicle soon" and no warning lights are illuminating then disregard these codes.
Hope helps.
U1064 code & can't check the codes on a scanner. engine starts & dies. when it was running the abs light & brake lights were on & theft & service lights were on.
Sounds like a blown fuse to one of the computers, either the ECM (engine control computer) or the BCM (body control computer). The ECM fuse should be under the hood and the BCM fuse in the cabin. The U1064 means a loss of communication on the data line between computers (64 usually is the BCM). If the computers can't communicate they will shut down the engine and set trouble codes. The other issue could be a faulty ignition switch not allowing power to a computer (but not common for cavaliers or sunfires). If fuses are good, chances are you have a faulty computer somewhere in the data line, shorting out communication.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
