Question about InFocus LP 600 Multimedia Projector
Faded Black Strip on Side of Projection
The Left side of the screen is faded (see image) The faded portion is not straight up and down, the fade is wider at the bottom. The fade is present with and without sources plugged in. When the projector is mounted on the ceiling, the fade is on the other side. I called InFocus and they had me remove and shake the lamp a bit, and said it shouldn't be a lamp problem. Any ideas?
Anonymous
I had a similar problem with my InFocus LP600 although my black stripe was straight up and down. I am guessing this is caused when the unit is bumped or dropped. This is not an easy fix unless you have a lot of experience with small tools and parts and you may need an extra set of hands. I found some tiny alignment screws under the lamp cover and hidden beneath a peel-off 0.5" x 2" black plastic strip. The screws are located between the bulb assembly and the main projection lens and are oriented 90 degrees apart around the light projection path. The trick is in getting the projector to temporarily function with the lamp cover off -- it has an interlock tab on one edge that pushes on a microswitch when closed. We turned the projector upside down but raised on some slats for heat dissipation, gently held the interlock switch in with a small screw driver, and plugged in the power cord. After pushing the power switch to get the image, I adjusted the tiny screw that is angled towards the front of the projector and the stripe dissapeared! Since your stripe is angled, you may need to adjust both alignment screws. The screw heads are very tiny torx bit types but I was able to use a 3/64" (.05") allen (hex) wrench that came in a set of cheap jewelers type tools that are widely available. Be very careful while operating the unit with the lamp cover off as there are very hot surfaces and exposed wiring.
Posted on Dec 05, 2007
sheridan1952
  • 26 Answers
It may be an alignment issue, but it is also likely that the light tunnel has failed.
Posted on Feb 28, 2008
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Faded black and white printouts
If you remove the toner cartridge and gently shake it side to side, then reinstall it, does the problem go away, or come back after a few pages? I would suspect you have a bad toner cartridge/image unit and recommend you put in a new one.
Jan 24, 2014 | Xerox Phaser 4500 Printer
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Dell Color Laser 1320c printer. The left side of page prints lighter than rest of page - color faded or lighter
I also had this problem with faded print down the left hand side. I decided to strip the printer down. I had to completely remove the laser imaging unit which meant removing all the covers and a couple of circuit boards. I then cleaned the lenses/mirrors inside the open front and laser head (behind a flap with laser warning sticker) with compressed air. This cured the problem but took a couple of hours. I wouldn't recommend doing this unless you are reasonable competent with electro mechanical devices.
Having seen the laser imaging unit out of the printer, it seems a real shame that it wasn't manufactured to be air/toner tight as this could have been achieved at a small cost.
I hope this is helpful ;)
Jun 09, 2010 | Dell 1320c Laser Printer
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
Faded printing on left and right
Hello sir; Believe or not , you need to replace imaging unit.
May 14, 2009 | Ricoh Aficio CL3500N Laser Printer
OkiC5200 has an inch wide faded print line down the left side
It might be a dirty led assembly. The leds hang down from the top when it is opened.
May 03, 2009 | OKI C5200n Laser Printer
Faded on left hand side
If it only happens with the black then you need to change out the black toner cartridge. The good news is isn't doesn't happen with color so it more than likely not the printer but the toner.
Jan 09, 2009 | Samsung CLP 300 Laser Printer
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
TT
Nov 24, 2007 | Samsung ML 1710 Laser Printer
InFocus LP 600 Multimedia Projector Logo
757 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
martin hogg
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
