I need to type same information on 6 forms. Is there a way to save information and select key to duplicate.
First be sure the batteries are are good and the holder is clean and making contact. On the L. side of the keyboard are 3 keys marked save , play and delete hold the store key enter an address 01-99, release the store key, type info, press store again. To reprint ho;d play and enter the address, release play.
DickyO
SOURCE: IBM Wheelwriter 30 Series II
On the l. side of the keyboard there are keys labeled store, play & delete. Press & hold store then type an address 01 thru 99 release store and type whatever you want. Upon completion press store again. To play it back press play and the address, to clear delete and address.
DickyO
SOURCE: needing bold typing on IBM Wheelwriter 6 Series II
To get bold you need a WW 10, 15, 1000, 1500 or any of the later models have this faeture.
DickyO
SOURCE: We have an old IBM Wheelwriter 6 Series II
First thing be sure the batteries are good. When it powers up it should beep once and the 1 light will come on. If that dosen't happen change the batt. and be sure the contacts aren't corroded.
There are 3 keys on the left side that say store, play and delete, hold the store while typing an address 01 - 99, release store, type info press store again. To print hold play and typa address. Delete works the same way.
DickyO
