Need to replace
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
SOURCE: i have a sony bravia
With the lights in the room turned off, does your TV screen still glow when it is turned on even though there is no picture signal there?
If your screen stays completely black, then most often, this symptom is a result of a failing POWER SUPPLY, but a faulty BACKLIGHT INVERTER BOARD can certainly cause very similar symptoms. Unfortunately, without a donor TV to swap parts with or a dedicated test rig, it can be very difficult to differentiate between these problems.
One way to quickly test this is to remove the rear access panel on the TV and replace the power supply circuit board with a new one, since this is the most often the source of the trouble.
You can usually find replacement circuit boards online by searching for your TV's model number.
Here is a link to the SHOPJIMMY.COM parts supplier website with all the replacement circuit boards available for your model of TV:
http://www.shopjimmy.com/sony-kdl-40s2000
And here is a link to a POWER SUPPLY CIRCUIT BOARD for your model of TV currently available online from SHOPJIMMY for about $68 US plus shipping:
http://www.shopjimmy.com/sony-a-1144-543-e-g2-power-supply.htm
And here is a link to a replacement BACKLIGHT INVERTER BOARD for your TV which is unfortunately currently out of stock. The online inventory does tend to change pretty regularly so if you do end up needing this part, you can always check back later to see if one becomes available:
http://www.shopjimmy.com/sony-1-789-500-33-backlight-inverter.htm
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
The repair / replacement procedure is not extremely difficult if you have some basic electrical safety knowledge and some basic electronics / mechanical repair skills.
You will need to unplug the power cord from the unit, lay the TV screen side down on something soft and flat like a bed, and then remove the rear access panel or the entire rear cover as required in order to access the circuit boards inside.
When you remove the rear cover and access the circuit boards inside, just check the part number that is printed right on your circuit boards and confirm that they exactly match the ones provided in the online listing. Also make sure that any part you order is labelled "TESTED WORKING" in the condition description. Any part with a condition description of "AS IS" is probably faulty itself as well.
Then unclip and remove the various electrical wire connectors leading to the power supply circuit board. Then remove the screws securing the circuit board to the TV frame and then remove the power supply circuit board. Be sure to avoid touching any large capacitors on the circuit board which can retain a nasty charge even after the unit is unplugged.
Then just screw in the new circuit board and connect all the wire bundles to their appropriate connectors on the new circuit board and then replace the rear cover. Then plug in the power cord and test.
Here is a link to another Expert's solution to a similar problem which includes links to his excellent and informative set of LCD TV / MONITOR TROUBLESHOOTING GUIDES:
http://www.fixya.com/support/t10008425-when_turn_tv_picture_flicks_off
These guides will give you some idea of the various problems with LCD monitors and the associated repair procedures.
If you choose to rate BUDMRTN's troubleshooting tips by clicking on the YES THIS WAS HELPFUL icon on his solution page at the above link, then I thank you very much for your time and consideration.
Please comment back here to this page if you have any details to add, have any questions, have difficulty with the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
Joe.
