SOURCE: Radio won't charge!
I don't know that I have your solution, but I do have a few troubleshooting tips.
Flashing typically means: your battery is possibly old, bad or is not making good contact. Clean your battery contacts with a pencil eraser to ensure they are making good contact with the charger. Also check your charger contact to see that they are free of debris. They can also be carefully cleaned with an eraser. (Do not use any type of solvents on either contacts.)
Second, check the date code on your battery. It is 3 or 4 digit number on the label. Batteries last approx. 18-24 months before starting to fail. Here is how to read the code: 835 would be 2008 the 35th week. If the battery is more than 2 years old, you should consider replacing it.
It is wise to have your radio turned off while on the charger. You can cause harm to the radio if you inadvertently press the PTT while the radio is on the charger. Plus, your radio will never fully charge if left on.
SOURCE: i have no manual
look at the date stamp on the battery label. if it reads as 711. it is 2007 week 11. they are not made to last more than 18 months in normal industrial use
SOURCE: Motorola CLS 1450c radios microphone problem.
The problem you are experiencing is not a mic problem, or the problem would also be associated with the two-way radio portion of the radio. Your radio is either in need of repair or you have a bad, low or defective battery. It takes more energy to transmit or use the unit as a phone than to simply receive.
If your radio is under warranty (less than 1 yr old) you can return it to the place of purchase for warranty replacement or service. After warranty repair is also available through Motorola's factory depot. Ask your local dealer.
SOURCE: does a Motorola cls 1110 work with a motorola talkabout sx600R ??
It appears they do not have any frequencies in common.
Best regards.
SX series guide: http://www.banoggle.com/Products/Motorola/manuals/SX900-manual.pdf
CLS series guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf
SOURCE: My Motorola CLS1110 Two way
You may have a bad battery, or even dirty battery contacts. A few troubleshooting ideas include:
1) Swap the battery to another known good CLS1110 radio and see if the other radio has the same problem when placed on the charger. If so, you have a bad battery. This type of battery typically lasts approx. 18-24 months before needing replaced.
2) If swapping the battery proves to be successful, check the battery contacts on the affected radio for debris, scum or dirt. Clean the contacts on the charger and the radio with a pencil eraser if needed. (The fact you have to readjust the walkie in the charger indicates you might have problems with the contacts.)
3) Try the battery from the known good radio in the affected radio, if the battery charges correctly, you know the radio is fine. If the charger blinks with the known good battery, then you know you have a radio problem.
Best regards.
