Try hard reset, this has happened to me. Hold the power and home buttons until the logo comes onto the screen. Try this when your phone is plugged in just in case it is dead.
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response... iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Hello madelyntrist, Monitor totally blackout may from inverter problem. To make sure inverter or not, switch on than knock the panel smoothly. If you see flashing light on area knocked, that indicate inverter is ok. If that still any questions, please let me know.
Hi:
Unfortunately, it isn't a Windows problem, but a monitor power or backlight failure. Your monitor's high voltage inverter board, or the backlight has failed. Often it is too expensive to repair, and cheaper to replace the monitor if it is out of warranty
check your fuse first. its located inside the near the power cord connection in PCB. If the and switches are okay, possibly the transistor or IC are defective.
try resetting it by holding both the power button and home button at the same time.
Wait until you see the apple logo appear before releasing both buttons
also make sure that it is charged
You either have a screen that has gone and needs to be replaced or a cheaper fix and usually a more likely one is that the inverter in the screen has gone out. The inverter is quite cheap, around $34.00. Try it
