Computers & Internet Logo
A
Anonymous Posted on Aug 13, 2014
Hewlett packard instruction manuals
How can I fix my HP laptop when its saying error occurred while attempting to read the boot configuration data?
Brett Duxbury
Level 3:
  • HP Master 4,352 Answers
  • Posted on Aug 13, 2014
Brett Duxbury
HP Master
Level 3:
Answers
4352
Questions
0
Helped
1118672
Points
13423
Http://sourceforge.net/p/boot-repair/home/Home/
On another computer download ISO image and use infrarecorder to burn a cd that will become a boot disk.
The tricky part if it has IEFU new bios it will not boot unless you turn off safe booting in the bios and change the boot order to boot from a CD if it has a CD or USB otherwise you will have to google how to make a USB Boot from a
USB stick. https://www.youtube.com/watch?v=ApRK8av2IOI
The new laptops do not spell out how to chage the bios but you have to press and hold down f2 key at power on
5 Related Answers
Joed911
JDTec
  • 4338 Answers
  • Posted on Nov 02, 2008
SOURCE: RESTORING WINDOWS/BOOT MANAGER
Sounds like you have Vista. Here is a link on creating a Vista recovery cd:
http://neosmart.net/blog/2008/windows-vista-recovery-disc-download/
This link is a how to document on repairing the BootLoader:
http://neosmart.net/wiki/display/EBCD/Recovering+the+Vista+Bootloader+with+EasyBCD
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
  • 34 Answers
  • Posted on Apr 29, 2009
SOURCE: Windows failed to start
Try safe mode if you can. if you cannot and it is windows xp repair install. if vista tell it to do fix it via the vista disk.
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Dec 21, 2009
SOURCE: My laptop will not boot. Says error occurred
this is a problem with the boot sector data ...the quick fix will be like this :
insert the operating system disk ...and restart ...choose to boot from the disk ..if it is not set to boot from the disk as priority ...it will not ask ya to press any key to boot from the disk ...in this case you have to go to bios by pressing del or F2 on start ...and there select the cd/dvd device as primary booting device ...press f10 to save changes and reboot...
it will start configuring your operating system again ....but after loading files ...when it gets to the first repair...just choose it ...(R) and it will get to a repairing sectore where it will ask for a command..
the proper command to solve your problem si : fixboot ...this wwill make it rewrite the boot sector and solve the problem ...
if you do not manage ...just let it reinstall the operating system ..but save the files before in another partition ...
Anonymous
  • 53 Answers
  • Posted on Apr 05, 2010
SOURCE: computer wont reboot
The issue is due to presents of earlier operating system files which are avoiding you to reinstall the os.
At this point I recommend you to clean the hard disk and then try for fresh installation. However, I am providing you the steps below:
Perform the steps provided in the below web site and then perform the Reinstall process
http://killdisk.com/downloadfree.htm
NOTE: The URL above will take you to a non HP Web site. HP does
not control and is not responsible for information outside
of the HP Web site.
After performing the complete format of Hard Drive, Reinstall the Windows XP.
To reinstall the operating system, follow the steps below:
1. Ensure that the CD-ROM is connected to the notebook.
2. Turn on the notebook.
3. Immediately insert the operating system CD into the CD drive.
4. Press and hold the Power button for 5 seconds to turn off the notebook.
5. Press the Power button again to start the notebook.
6. Press Esc key to boot from the CD when HP logo appears. Choose the first boot device as CD ROM and then click enter. The Welcome to Setup screen is displayed.
7. Press ENTER to continue. A Licensing Agreement screen is displayed.
8. Press F8 to accept the agreement and continue. The Setup window is displayed.
9. Press ESC to continue installing a fresh copy of the operating system without repairing.
10. Press ENTER to setup the operating system.
11. Press C to continue using this partition.
12. Select "Format the partition using the NTFS file system (Quick)", and then press ENTER. A caution message stating that formatting this drive will delete all current files, is displayed.
13. Press F to format the drive. The reinstallation process begins and may take several minutes to complete. Your Notebook will restart into Windows after the process is complete.
NOTE: When prompted for the product key, refer to the Microsoft Certificate of Authenticity located on the bottom of your
notebook.
I hope this information helps you. Please reply if I can help you further.
Scott P
  • 1087 Answers
  • Posted on Aug 17, 2010
SOURCE: An error occured while attempting to read the boot
U will have to extract the Windows CD to a file folder on your pc. Run Nlite to make a bootable file to load to ur flash drive. Then u will need to set ur bios to boot from USB device. Mainly needing the Boot.INI
Blue screen on envy 13 admin password prompt with system disabled - CAN YOU FIX HP ERROR CODE 64449838
I can only help with the system admin password (presumed windows). You will have to manufacture a "Password Reset Disk" on another PC or laptop (preferably running same OS - you will need your product key COA number). Instructions on MS website. Also - check your BIOS settings are OK when setting to boot on the password reset disk. That will be F1 or DEL probably on power up.Good Luck.
2answers
How to fix windows start up error in a hp?
You can't. You have to reinstall the operating system.
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem: 1. Insert your windows installation disc and restart your computer. 2. Choose your language settings,...
Big trouble. Try safe mode, if possible. Don\'t use recovery procedure, just manually remove unnecessary things. Finally backup your data, and reinstall whole system?
Window error recovery
You can try to fix the issue by Windows Boot Genius, it is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.
Free Download:
http://www.windowspasswordsrecovery.com/windows-boot/
Windows 7 boot manager missing after buying and loading restore disks from hp
The error befalls when your PC is unable to interact with Windows due to the corrupted Windows installation, or it is trying to boot from a wrongly configured or improperly connected hard drive or flash drive among other external medium...... read more
TouchSmart 310 won't boot up .
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
An error occurred while attempting to read the boot configuration data
my 4211c wont boot up all it does is say press alt ctrl and del to start system but when you do that nothing happens
What is file error 0xc000000e
File: \Boot\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
Windows Boot Manager
1. Insert your Windows Installation disc and restart your computer.
2. Choose your language settings and then click "Next"
3. Click "Repair your computer"
If you do not have this disc, contact your system administrator or computer
manufacturer for assistance.
ERNZ
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
