Question about Horizon T91 Treadmill
What does "lube bell" mean
The words "lube bell" have appeared on my screen on the treadmill. The belt will not start. Do you have any suggestions on how I may fix this?
Posted by Shahana Black on
Brett Duxbury
  • 4,290 Answers
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
After lubing the belt on my Horizon T101 it started tripping the breaker after 5-15 minutes of use. It never did this before I lubed it. Any suggestions?
Step 1:
1) the old board deck belt is time to replace it
2) However you must test a) the main motor see my personal TIPS for motor help b) test the output voltage board, for input voltage motor if there are NOT the board is faulty. see the diagrams attached.
God bless you
Step 2:
Step 3:
Jan 09, 2013 | Horizon Fitness T101 Treadmill
White powder-like substance on belt
Dear Sir:
LUBE the deck belt, is lack of maintenance, maybe you have to change the deck belt, this produce enough friction and shut down the machine for to protect the electronic system.
2) lube THE ROLLERS bearing , according with the maintenance schedule.
3) Clean any EXCESS of wax, and LUBE very well.
4) Test the input motor if there voltage the motor need repair.
God bless you
May 09, 2012 | Proform XP CrossWalk 580 Treadmill
Were do you lube the bell for the treadmill t700
you mean belt not bell . you put lube on the board each side in a zigzag motion. litely
Feb 25, 2011 | Exercise & Fitness
What does it mean when it sayd lube belt?
I have treadmill. show indicator lube belt . what that'smean
Dec 21, 2010 | Horizon T92 - Treadmill
Appeared on the screen of the device that need oil, but does not have a place to fill the place of oil????
The only place to oil is under the walk belt. You dont need to worry about it. If you want to, you can order a kit from iconservice.com.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 05, 2010 | Reebok Vista Treadmill - RBTL13305
Can walk on it but when i start to run the belt stops and all the electronics go off then come back on
Sounds like the belt and deck needs lubrications. Why I say that when walking you do not drawn as much power as you would running. IF their is a lack of lubrications their is a higher amount of friction thus the Motor Control Board has a internal shut off which prevent further damage to the treadmill. This is a fact that 75% to 85% of the problems are belt and deck related. So i suggest you call Nation Gym Supply @ 1-800-496-7278 order this lube part # TM001 Follow these steps below:
Lift the belt and use approximately ½ of the tube by squeezing the lube in the walking area lengthwise. Move to the opposite side of the treadmill and repeat using the remainder of the lube. Use all of the contents of a single container during application. The lube will spread evenly in the next step. Do not perform this step by hand. The lube is usually not harmful to the skin but has the potential to permanently stain fabric.
Start the treadmill at 2 mph and walk on for about 5 minutes then check centering carefully and adjust as needed following your owner’s manual instructions
May 21, 2010 | Nautilus Sport 5.18 LC Treadmill - Huge...
Horizon T91 Treadmill Logo
693 people viewed this question
Top Horizon Exercise & Fitness Experts
gbob59
Vernon Taylor
john h
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
