Try here
http://us.ute.com/services01.php?rbu=5&select1=148&select2=386
Or you can try using driver for Prolific PL2303. Get it here
Also forgot to mention that the drivers I posted are used if you are using USB to connect your 206. If you are using the serial connection (9 pin plug) then just plug into a serial port if your computer/laptop has one and then just set the com port in the encoding software. If you don't have a serial port to plug into then you can add one by purchasing a pci addon card if it's a desktop. You can also buy a serial to usb adapter that will work with both desktop or laptop. And yes it will work in windows 7. I have used them in both windows 7 and windows 8. If you go with the adapter make sure the one you buy has a true prolific chip in it. There are a lot of counterfiet ones being sold and prolifics driver will detect it and prevent it from functioning. So don't buy a cheapy.
SOURCE: MSR 206
there is no way to use it with win7 if driver not supported...you reader is only support with win98/2000/nt
