The knob and the stem which the knob fits into have been broken off of my frigidaire professional series kitchen range, how can i replace it?
SOURCE: A Broken Stove
whats the entire model number?? and you cracked the main top glass assy??? ill look up tha part for you, not a teribly hard job, but depending on glass may be expensive
SOURCE: Where is the fuse panel
I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
Phil
SOURCE: Frigidaire PLES389DCC MODEL Electrolux
318223626 -
MAIN TOP
found it listed from 230.68 at prosupplyco.com
up to 281.85 at Repairclinic.com
hope this helps,
best of luck,
ttfn
SOURCE: How do I replace a broken stem on the griddle knob
You would remove all of the knobs and then you remove the screws holding the face panel on there. Then you can access burner valves. The new part may not come with a preset orifice because the factory does not know which type of gas you have. So what they do is tighten the orifice all the way down. Lets see if I have a viking service manual:
Hi
You will have to replace it with a new one, remove the old
one and simply replace it with new one. Hope this helps...please post back for
further assistance.
Daniel
