No, never will iPhone settle an SD card in Apple device. However, you can still transfer iPhone data to external SD card with some ways. If you want to do so, just follow below steps.
When you want to transfer files from iPhone to SD card, you will also need the help of iTunes. iTunes provides a Transfer Purchases function so that the users are able to transfer all purchased items to iTunes library and copy them to the SD card. When you plug iPhone into computer with USB cable, iTunes will launch. Then you can click "File > Devices > Transfer Purchases" at the upper left corner to transfer the purchased items to iTunes library. Then you can find the files in iTunes folder, and copy these files to SD card easily. But the non-purchased items won't be transferred to iTunes library with the Transfer Purchases function.
You can take advantage of the third-party iPhone transfer software to transfer files between iPhone and SD card directly. People can various kinds of iPhone transfer programs on the Internet, and Leawo iTransfer is regarded as one of the best. This software is used for transferring files among iOS devices, iTunes and computers without the sync of iTunes, and it helps users to transfer various kinds of files. The following guidance will set transferring photos as an example and show you how to transfer files from iPhone to SD card, and you are allowed to free download the software to have a try. Note that the trial version has limited transfer times.
Run Leawo iTransfer
Run Leawo iTransfer and connect iPhone to computer with USB cable. The software will recognize your iPhone, and automatically detect the libraries of it.
Select Files
Choose the "Music" library in the left sidebar, and then the contents will show up in the right part. Click the transfer button at the right bottom to transfer all the music; or hold "Ctrl" key and choose certain files, then right-click the selected files to "Transfer to > My Computer".
Transfer Settings
After selecting files, you will see the pop-up dialog of transfer settings. Check "Save to Folder" and click "Change" to choose a folder in the SD card to save the transferred files. Then click "Transfer Now" at the right bottom to start transferring files from iPhone to SD card.
Transferring Files
Leawo iTransfer will start the transfer immediately after the button is clicked. The progress bar in the pop-up dialog will show the progress of the transfer process. When the transfer is finished, you will get the files in the target folder.
For more details, check: How to Transfer Files Between iPhone and SD Card
No. You can only save data in its internal memory.
No. The only card you can insert in any iPhone is the sim card. You should buy a iPhone with enough memory for all the apps you want to use and for all the content, like notes, music, contact list and so on.
Although the iPhone used to come with 8 Gbyte is is really not enough as soon as you start to put apps and music on it.
New phones should have at least 32 G Byte.
But if you plan tu use a phone for a few years at least, take the 64 G byte. That goes for the android phones too. Because even when you can enter a 32 G byte memory card in an android. It will not be an extension of the main memory. You can't install apps or access lists of contacts as long as the are on the extra memory card. It is more like a had drive, from which you need to cpu the content to the main memory first, before you can use it.
