Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Model 970 247720
Can't reset temp to -23 , buttons wont allow to adjust to c or f , or move temp to -23
Posted by jake blume on
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
We moved our freezer model lffh21f7hwe to another location, turned it on, checked it later and it was -10, I tried to raise the temperature up, now the light says OF. What do we do?
try to unplug the unit for a few minutes.then try and adjust you temp again if you you to high with the temp you will shut it off
Oct 10, 2010 | Frigidaire Freezers
My Freezer does not maintain the right temp. It wont maintain my food frozen.
The thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Turbo Air 23 cu. ft. / 651 liter...
TEMP ON FREEZER IS NOT COLD ENOUGH WHEN SET TO -23 KEEPS RETURNING TO -9. there are three buttons on the top of the fridge, one with a speaker sign, one saying SUPER and the third with the degree sign....
Sounds like you need to do a 12 hour defrost. If the evaporator is caked with ice, the thermistor(temp.probe.) will also be covered. the true temp wont be read in this state. Defrost and then retry. Take note of temp for a period of time. See if it ever goes to -20 as selected. If so then at a later date it goes off again, there is then a defrost issue. Suspect the door was left open accidentally.
Jun 04, 2010 | Freezers
Deforst mechanism
you need to have a defrost or the freezer will not work unplugging the time clock then the compressor will not work. Tom
Jun 18, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Freezers Logo
160 people viewed this question
Top Kenmore Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
