SOURCE: I have a invacare wheelchair pronto91 wont move 2
The three light flash indicates a short circuit between the left motor(as you are sitting in the chair)and the battery. Check all the wiring from the control box to the motor and make sure it is not damaged in any way. If it is okay, you have most likely fried the left side motor. A new motor-gearbox assembly for this chair runs in the neighborhood of $1,400.00, or you can take the motor off and take it in for a full rebuild for about $250 or so. Unplug the joystick and remove the seat and cowl. Jack up the left side with both motors in gear. Remove the center nut cover and take off the nut holding on the wheel taking care to retain the key that slides into the groove on the axle. Disconnect the wiring plug to the motor and remove the six bolts holding the motor to the frame. Separate the gearbox from the motor and take the motor to a rewind shop for repairs. Reinstall and it should be good to go.
SOURCE: Had the Pronto M91 invacare wheelchair in the Push
You definitely need new batteries. After that amount of time the batteries go bad and the plates inside become sulfated. They are only good as boat anchors now.
It is a easy do it your self repair. There are 2, Group 22 batteries in this model. You want to get deep cycle sealed lead acid, preferably AGM (advanced glass matt) group 22 batteries.
Flip the seating system back by releasing the lever under the front of the seat.Make sure you do not pinch the joystick wiring at the back when you do this.
Remove the black plastic cover.
The batteries will be secured by a strap which you should unbuckle.
Disconnect the plugs to the batteries and note how they are run, oriented and connected.
Pull out the batteries, one at a time, from the base.
Make the wiring connections to the battery , put the batteries back in the chair, plug everything in and you are set to go. Hope this helps.
SOURCE: m51 charger has solid red light and a blinking green light
Battery is shorted or may have cristlized replace battery. This will solve your problems.
