Carbrio model number WTW6400SW2. It shows either a 7 or 12 after I open the lid. It drains and spins great except at the very end. I've even dried using the rinse/spin option on low and the drain/spin. It does the same thing every time.
SOURCE: Computer board shows UL even when very few clothes are in the washer
try to unplug and plug back after 30 seconds.
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: won't spin
As previously suggested, try cleaning out the drain system. See my solution at http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
