0x40028e28 referenced memory at 0x00000000
The error "Instruction referenced memory 0x40028e28 referenced memory at 0x00000000" may indicate that the program you are using is trying to access memory that is not allocated or has been corrupted. This can be caused by a variety of factors, including software conflicts, hardware issues, or malware.
Here are some steps you can try to fix the problem:
If none of these steps help, you may need to contact a technical support team for further assistance. It is also a good idea to check the documentation or manual that came with the software or device for any troubleshooting tips or recommendations.
Posted on Dec 21, 2022
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe
%FontsDir%\nwlnkipx.exe
%FontsDir%\nwlnknb.exe
%FontsDir%\nwlnkspx.exe
%FontsDir%\nwrdr.exe
%FontsDir%\oprghdlr.exe
%FontsDir%\p3.exe
%ProgramFiles%\internet explorer\keymaker.exe
%ProgramFiles%\outlook express\keymaker.exe
%System%\1025\zipfldr.exe
%System%\1028\zipfldr.exe
%System%\1028myztx.exe
%System%\1031\zipfldr.exe
%System%\1033\zipfldr.exe
%System%\1037\zipfldr.exe
%System%\1041\zipfldr.exe
%System%\1042\zipfldr.exe
%System%\1054\zipfldr.exe
%System%\2052\zipfldr.exe
%System%\3076\zipfldr.exe
%System%\3com_dmi\edb.exe
%System%\3com_dmi\edb0000a.exe
%System%\3com_dmi\edb0000b.exe
%System%\3com_dmi\edb0000c.exe
%System%\3com_dmi\edb0000d.exe
%System%\3com_dmi\edb0000e.exe
%System%\3com_dmi\zipfldr.exe
%System%\catroot\zipfldr.exe
%System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe
%System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe
%System%\catroot2\tmp.exe
%System%\catroot2\zipfldr.exe
%System%\com\zipfldr.exe
%System%\dhcp\zipfldr.exe
%System%\directx\zipfldr.exe
%System%\dllcache\zipfldr.exe
%System%\drivers\disdn\ws2ifsl.exe
%System%\drivers\etc\atmlane.com
%System%\drivers\etc\atmuni.com
%System%\drivers\etc\audstub.com
%System%\drivers\etc\battc.com
%System%\drivers\etc\beep.com
%System%\drivers\etc\bridge.com
%System%\drivers\etc\cbidf2k.com
%System%\drivers\etc\ws2ifsl.exe
%System%\drivers\ws2ifsl.exe
%System%\drivers\zipfldr.exe
%System%\export\zipfldr.exe
%System%\grouppolicy\adm\gpt.exe
%System%\grouppolicy\gpt.exe
%System%\grouppolicy\machine\gpt.exe
%System%\grouppolicy\user\gpt.exe
%System%\grouppolicy\zipfldr.exe
%System%\ias\zipfldr.exe
%System%\icsxml\zipfldr.exe
%System%\ime\zipfldr.exe
%System%\inetsrv\zipfldr.exe
%System%\keymaker.exe
%System%\macromed\comadmin.exe
%System%\macromed\comempty.exe
%System%\macromed\comexp.exe
%System%\macromed\edb00017.exe
%System%\macromed\res1.exe
%System%\macromed\res2.exe
%System%\macromed\tmp.exe
%System%\macromed\zipfldr.exe
%System%\microsoft\zipfldr.exe
%System%\msdtc\msdtc.exe
%System%\msdtc\trace\msdtc.exe
%System%\msdtc\zipfldr.exe
%System%\mui\0418\ftdisk.exe
%System%\mui\0418\gm.exe
%System%\mui\0418\gmreadme.exe
%System%\mui\0418\hgfs.exe
%System%\mui\0418\http.exe
%System%\mui\0418\i8042prt.exe
%System%\mui\0418\imapi.exe
%System%\schost.exe
%System%\services32.exe
%System%\spool\drivers\w32x86\3\mouclass.sys
%System%\spool\drivers\w32x86\3\mountmgr.sys
%System%\spool\drivers\w32x86\3\mqac.sys
%System%\spool\drivers\w32x86\3\mrxdav.sys
%System%\spool\drivers\w32x86\3\mrxsmb.sys
%System%\spool\drivers\w32x86\3\msfs.sys
%System%\spool\drivers\w32x86\3\msgpc.sys
%System%\syskey_dll\sysupdate.exe
%System%\system\system.exe
%System%\tmp.exe
%Temp%\5.exe
%Temp%\70554keygen1.exe
%Temp%\guqf296\keymaker.exe
%Temp%\ixp000.tmp\efubtgis.exe
%Temp%\ixp000.tmp\key_gen.exe
%Temp%\ixp000.tmp\keygen.exe
%Temp%\ixp000.tmp\keymaker.exe
%Temp%\ixp000.tmp\tmp.exe
%Temp%\ixp000.tmp\tvonuaek.exe
%Temp%\ixp000.tmp\zwwltphz.exe
%Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
Posted on May 21, 2009
Hi there.
Go here and download Yahoo Messenger 9, then reinstall the software and post back if you have any success >>>>>>>
http://messenger.yahoo.com/download
Good luck and thanks for using FixYa!!
Posted on May 25, 2009
SOURCE: The instruction at "0x012cf496" referenced memory at "0x012cf496"
you should increase the virtual memory of system,to increase the virtual memory :-
->right click on my computer goto to properties tab
->then goto advanced tab
->performance setting
->advanced tab
->virtual memory
now increase the virtual memory with current
OR
:>type chkdsk command in dos
Posted on Jan 17, 2010
SOURCE: the instruction at "0x01003ce4" referenced
Seems like an application crashed on your Windows system. There are many reasons something like this could happen. Some ideas are:
- You may have a virus or malware in your system. Try getting an up-to-date antivirus and check the system (I recommend AntiVir which is free). Also, get a Malware clean-up tool, like Anti-Malware and do a full check as well.
- There may be an issue with your RAM chips, especially if you're getting this sort of errors all the time and from more than one applications. Try checking your memory for errors, with a tool like MemTest.
- This error might also indicate a driver problem. Depending on your system set-up and configuration, it could be a graphics card issue, sound driver or other hardware driver. Try getting the latest available version for all your peripheral's drivers, install them and try again.
- It might be the application's fault. There is also the possibility that there's nothing wrong with your computer but the specific application has a bug, which you're witnessing. Again, without more details, it's impossible to say for sure.
There are more cases in which such an error might come up, but try these solutions first and see if they help.
Posted on Mar 13, 2011
SOURCE: The instruction at "Ox7752c56c" referenced memory
Hello davidlange, could you describe what you were doing before you got this error message?
Posted on May 05, 2011
