SOURCE: Bissell 1699
Make sure that the piston on the bottom of the smart mix valve is in the water only position.(needs be be on the knob and not sitting in the hole). With the top off, it is easier if you have a block of wood or something under the base to hold it up. Other wise it drops down and the screws can't grap the base. Also make sure all hoses aren't being pinched.
SOURCE: need full manual for bissell pro heat 1699 upright clearview
you can download it from bissell.com. The link below will take you to the 1699 page, this has a link for the full manual.
good luck
http://www.bissell.com/Product_Search.aspx?Criteria=1699
SOURCE: need a manual for pro heat brissell model 1699
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
reyy536
SOURCE: My bissell 1699 pro heat clear view upright water
heatman101
y
