Can't remove the chopping blade from large bowl
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5.
Posted on Aug 12, 2014
SOURCE: Blade will not release
Our blade just came apart at the seam just above the blade, so we know what's inside. There is a small v-shaped piece of spring wire that is spread apart from the stem that is mounted to the machine. When the button is depressed (it's on a tiny spring, like a mattress spring, and that's what makes it bouncy), it spreads the v-spring wire and releases it. If you can get the seam apart, it will release the v wire and not damage the machine. Replacement blades are available on-line for $13.95, and whole machines are available on e-bay. Good luck.
Posted on Jan 06, 2008
SOURCE: food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Posted on Oct 08, 2008
SOURCE: chopping blade # 70207
customer service number 1-877-207-0923 for hamilton beach
Posted on Nov 16, 2008
If the blade is actually fused, I would seek professional help to avoid slicing your fingers off. You can test to see if it is fused by removing the lid of work bowl, twisitng work bowl to the left, and removing the work bowl - if work bowl will not come off (difficult even under normal circumstances), then find out from Cuisinart if you are still under warranty.
Posted on Dec 10, 2008
SOURCE: Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Posted on Aug 31, 2009
Jan 12, 2016 | Food Processors
Oct 05, 2014 | Food Processors
Feb 19, 2014 | KitchenAid Food Processors
Mar 08, 2011 | Braun K 600 CombiMax Food Processor
Feb 23, 2011 | Braun Food Processors
Apr 04, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Nov 27, 2008 | Moulinex DG6 Food Processor
Feb 07, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Jul 14, 2007 | Cuisinart BFP-703 SmartPower Duet Food...
Aug 25, 2015 | KitchenAid Food Processors
289 people viewed this question
