Question about Canon PIXMA iP4000 InkJet Photo Printer
Ip4000 5 times amber - Canon PIXMA iP4000 InkJet Photo Printer
Blinking amber light
power board problem
Mar 19, 2015 | Televison & Video
Amber light blinking next to ethernet cable
In most cases an amber lights are usually just connection lights. They let you know the ethernet cable is connected and able to transfer data.
You will want to ensure the printer has a static ip address set in it's configuration, otherwise the ip address will change from time to time causing print issues.
Jun 24, 2013 | Office Equipment & Supplies
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Canon Pixma iP1800: amber, green, amber, greeeeen flashing lights
what error message coming from your computer...i think something stuck inside your printer
Feb 24, 2010 | Canon PIXMA iP1800 InkJet Printer
1 green 7 amber
I have the same problem and haven't yet got an answer!
May 31, 2009 | Canon BubbleJet i560 InkJet Printer
No Heat and I'm Cold
Your preasure switch is closed
Dec 05, 2008 | Heating & Cooling
Amber light remains lit at all times
Did you try to replace the battery?
Nov 25, 2008 | HP iPAQ hw6915 Smartphone
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
Nov 05, 2008 | Canon i80 InkJet Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
119 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
