Be sure you've left it on charge at least 12 hours while switched off. If still no success, it could be a bad battery or charger. Try emailing or being phoned back by Kindle support at <https://www.amazon.com/gp/help/customer/contact-us>
If you've explored all options with software settings and If you're outof warranty, you can try to open the kindle and replace the battery.There is a Kindle Repair Guide that shows you how to take it apat. There are services that can do it for you. Kindle Repair.
May 16, 2015 - You turn on your Android phone or tablet by pressing its power button ... Charge Your Phone or Tablet For a Few Minutes ... If it doesn't work at all, try plugging the device in with a different .... Get downloadable ebooks for free!
Here's a possibility, I just plugged in my Kindle Paperwhite using the Kindle charger and USB cable. It wouldn't charge.
I kept it plugged in all afternoon and it accepted no charge although it showed the little lightning bolt on the icon suggesting it was charging.
I unplugged the charger (it has two prongs) and reversed it so
the logo was on top and, Lo and Behold it charged. It could be the plug is not omniidirectional (i.e. it is polarized)
The Kindle Fire HD, if completely discharged, may take several hours to begin to accept a charge again. Simply leave it plugged in long enough and the on-board system will sort it out.
Are you sure your charger is working? Try charging another device with it, or try using a different charger. If you're sure the charger is OK (and plugged in!), try leaving the charger plugged in to your Kindle for a good long while, like 12 hours. If it still doesn't charge, or if the charge wears down after a short time, you might well have a bad battery. Unfortunately, later-model Kindles don't have user-replaceable batteries, and having it done professionally is not cheap. If it's still under warranty, make sure to have it fixed before the warranty expires.
have you tried a new charger?? the contacts on your charger plug may be dirty....or the contacts on your kindle charging port may be dirty. Go to YOUTUBE and see how to clean a mini usb charging port, and or charging plug.
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Her is a possible solution: 1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours. 2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3. 3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger. 4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours. 5. Unplug the Kindle from the charger. 6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7. 7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
Sounds like the software than manages the charging is frozen. Try these steps to fix the Kindle. Step 1: Plug the Kindle into the charger Step 2: Press and hold the power button for 30 seconds making sure the Kindle is OFF Step 3: Let the Kindle charge in this state for 60 to 8 hours Step 4: While the Kindle is Plugged into the charger, press and hold the power button for 30 seconds, then release the power button. Wait for 10 seconds. Step 5: Press and release the power button normally, the Kindle should wake up and the charger system should be reset.
Let's try to reset the charger system. Step 1: Unplug from the charger, press and hold the Power button for 30 seconds Step 2: Plug into the charger. Press and hold the power button for 30 seconds Step 3: Let charge for 12 hours Step 4: Unplug form the Charger, run the Kindle until totally dead. Step 5: When DEAD. Press and hold the power button for 60 seconds. Step 6: Plug into the charger, let charge normally If this does not reset the charging system you have either a faulty Kindle or a faulty charger, contact Amazon for replacement.
